The most common cause of rough idle?
What are causes of rough idle with these engines? my engine has always had a rough idle I think it might be a bad engine mount but I am not sure
At red lights I can feel a vibration in the streeling wheel
let me rephrase it's not rough idle it's vibrations mostly felt though the steering wheel at stop lights when I go into N or P the vibration in the streeling wheel is gone but can still feel slight engine shake while it idles back into drive and the steering wheel vibration returns
My car had a little shake at idle when I got it, but after cleaning the throttle body, MAFs, and running a can of BG 44K, it runs silky smooth.
Second this. Good idea to start with the basic maintenance items.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also I never understood throttle body cleaning can the little bit of sludge build up effect anything? or is it the placebo effect?
These can be combined as well: Idle valve stuck open + Main flap donīt close + airflow sensor is dirty and donīt have correct measurement = Engine running lean and ECU think all is good. Add faulty or very old Lambda sensor on it and we have a perfect mess where no faulty codes but engine hardy even run.
Harry Dredge
Nov 2, 2015 12:31 AM
