XJ ( X351 ) 2009 - 2019
Need help!
Old Jun 26, 2023 | 08:48 AM
Berger83's Avatar
Default Need help!
New to the site need help! I just recently installed a new fuel pump and flange on a 2011 xjl 5.0l in February just this month the car died out and threw a code p0627 got a new fuel pump under warranty after installing it I’m not getting the p0627 code but I’m getting a new code for p008b low pressure fuel system pressure-too high I bought a new fuel pressure sensor that is literally right by the fuel flange under the seat and nothing has changed I never got this message with the fuel pump I installed in February what could this issue be thanks for any help
Old Jun 26, 2023 | 09:28 AM
12jagmark's Avatar
Which of the 3 fuel pumps did you replace? (it sounds like the in-tank LP one, but you weren't definitively specific)
Old Jun 26, 2023 | 09:56 AM
Berger83's Avatar
Hey sorry, I replaced the one right under the seat part number DELPHI FG1669 and the flange is new from the last one I replaced
Old Jun 26, 2023 | 11:41 AM
clubairth1's Avatar
Community Influencer
As 12jagmark said are you sure those errors are for the in tank pump?
You might have problems with the gear driven HP fuel pumps mounted up on the passenger side of the engine?
Here is a thread and note the burned connectors. Inspection will tell if you have this issue or not.
Jaguar P0627 Code - Burned ground wire
Old Jun 26, 2023 | 12:17 PM
Berger83's Avatar
Default Need help!
I actually noticed the burned ground and connector when I installed the fuel pump in February I was able to find the correct connector and wire terminals to redo the whole connector so that is all new I found that thread when I was researching the problem the first time I also replaced two of the fuses in the rear seat latch just to make sure there wasn’t a issue with the fuses
Old Jun 27, 2023 | 08:58 AM
clubairth1's Avatar
I wonder if the ground burned out again?
Symptoms sure seem to be the same?
Might be worth a look just to double check? It might have more problems than just a connector? Can you measure that it has a good ground now?
Old Jul 3, 2023 | 03:20 PM
Berger83's Avatar
Default Need help
Ok so I had to pickup the old oem fuel pump because it smelled like gas and fed ex wouldn’t pick it up I clearly can see the difference in the oem one and the one they gave me as a replacement it is surely a remanufactured fuel pump so I decided to throw the oem fuel pump back in since it still works but it did die out once so I’m not gonna keep it well it’s not throwing the code p008b or any other code but I have driven it and have seen fuel pressures drop down as far as 230 ish psi but the car didn’t sputter but once when the pressure was that low so where do I go from here
Old Jul 5, 2023 | 08:20 AM
clubairth1's Avatar
Maybe use a real OEM pump to replace yours?
Sounds like your aftermarket one has some kind of problem? Can you explain the re manufactured part? Fuel pumps are a wear item and I have always just replaced the entire pump with a new one?
Old Jul 5, 2023 | 08:26 AM
Berger83's Avatar
Default Need help
clubairth1, since fed ex didn’t pick up the fuel pump I was able to compare them side by side it’s the whole fuel pump plastic housing fuel level everything just found out it was a remanufactured one by comparing it the connectors on the oem one even say Germany on it and the other doesn’t there are more differences
alexx93
Jul 22, 2023 04:23 AM
Ashawnti1
XF (X260)
Nov 30, 2022 04:38 AM
Johndox10
Feb 24, 2022 10:28 AM
gameover
Jun 12, 2018 04:32 PM
62sunbeam
Oct 6, 2013 10:08 PM
