XJ ( X351 ) 2009 - 2019
New to Me 2014 XJL Supercharged
Old Sep 10, 2025 | 07:12 AM
clubairth1's Avatar
Community Influencer
Yes the WP to oil cooler brick tube is a well known leaker for sure!
Old Sep 10, 2025 | 04:01 PM
Six Rotors's Avatar
Default First DTCs Logged!!
I already have on my shelf all the aluminum pipes available---bought them in Florida last winter--and I have acquired all the seals and o rings from Jaguar to install them. I am in no hurry to install them as the previous owner had Jaguar install new versions of the plastic pipes. I monitor coolant level every time I use the car and I continuously monitor coolant temp, oil temp and battery voltage as have on my previous 2012 XF.
The car will be down all winter to do lubricant changes, brake fluid, power steering fluid, transmission fluid, work on grounds and the main power cable to the starter motor which has bad looking corrosion at the joining terminal. I plan to work on the car instead of going to Florida!
I also found out from my local Jaguar shop that they replaced the snout of the supercharger about 25kmiles ago and it is still very quiet.
I also had my first DTCs appear yesterday. P00BE-00 MAF B circuit air flow too low and P115D-00 Mass airflow circuit offset. There were no really noticeable effects driving at normal speeds just the orange engine symbol. So I spent an hour this morning pulling the MAF sensors and the intake tube to the throttle body and cleaned them with MAF cleaner and compressed air.
Cleared the codes and the car seems happy.
Old Sep 10, 2025 | 04:11 PM
Six Rotors's Avatar
I don't know if there is one under the SC on the 5.0L engines? Don't see anything about it in the forums like we did on the older 4.2L engines.
Got a picture or diagram of where it is?
If you look in the XF forum---XFRS Cooling System sticky it is shown as E8 and the part no is AJ813614
Old Sep 13, 2025 | 05:13 PM
Six Rotors's Avatar
Default Checking Under The White Ghost
Spent a couple of hours under the car today and removed the covers on the passenger side. Mainly interested in oil leaks, oil, coolant and power lines. So the good news is no oil leaks anywhere, no coolant leaks anywhere. The not so good news is corrosion on the terminals of the powerline connector and starter motor terminals. Found early enough to fix tomorrow. Pictures are attached.
power line corrosion
Engine ground
Engine ground
engine mount
engine mount
transmission mount
transmission mount
Old Sep 13, 2025 | 05:17 PM
Six Rotors's Avatar
Default More Pics
Transmission  mount
Transmission mount
Starter terminal
Starter terminal
passenger side brake and power lines
Oil level sensor
Oil level sensor
Old Sep 24, 2025 | 07:46 PM
Six Rotors's Avatar
Still making progress, all the terminals are cleaned up and protected with a surface coat of nickel based grease. The power steering fluid has been replaced with Mobil Multi-Vehicle semi synthetic Mercon 3 and tomorrow the differential oil will be changed using Valvoline Advanced 75W90 full synthetic. Also took a look at the AC system which was running with only 0.4ibs of refrigerant. After evacuating the refrigerant, the system held vacuum of -30in Hg for 30 minutes and then was recharged with 900grams of R134a. Then it will be ready for our Annual Leaf Run around cottage country this week end.
Old Sep 25, 2025 | 10:13 AM
clubairth1's Avatar
That thing will be better than new the way your going!
Any plans to change the transmission fluid? I might have missed it if you are.
Old Sep 25, 2025 | 03:46 PM
  #28
Six Rotors's Avatar
That's in the winter downtime program but I haven't really done anything yet---I was planning to get the ZF transmission fluid from Rock auto but it seems to have disappeared from their catalogue. However the transmission is working very smoothly and is noticeably smoother than the ZF6 speed and the fuel economy with rational driving is better than the 2012 XF. The real problem is remaining rational!
Just as a note it was a real pain changing the e-diff oil compared to the the 2012XF,but no metal particles on the drain plug just a little black sludge.
Old Sep 27, 2025 | 04:20 PM
Six Rotors's Avatar
Default Engine Grounds
I decided to do the engine grounds this afternoon. So far I have found 2 sets, the one on the passenger side front has 5 conductors on 2 terminals. It is located just below the passenger side air filter box and is shown in the attached pic after cleaning but before tightening.. You can see that I removed the fender liner so I could lubricate the threads of the 6mm steel ground stud before I attempted to remove it. The second one is located on the drivers side in a similar position just below the drivers side air filter box.
Old Sep 27, 2025 | 06:14 PM
  #30
KiwiJon's Avatar
Thumbs up
In response to an earlier post - I have the Foxwell 510 also - has done the job on my 2011 XJL 3.0D to date. Will have to get SDD one day I guess.
Lovely thread BTW - I am lusting after the 5.0 Supercharged. Not many in New Zealand, but I'm patient (and my wife is not yet onboard :-))
Last edited by KiwiJon; Sep 27, 2025 at 06:25 PM. Reason: Thought of something else to add!
Old Sep 28, 2025 | 06:28 AM
  #31
clubairth1's Avatar
Great pictures and did Jaguar finally go to bolts or are they still studs? Studs did not break? They look good and solid.
I did not even know where they were on the car either.
Old Sep 28, 2025 | 07:22 AM
  #32
Six Rotors's Avatar
In the engine compartment I have found two steel bolts which thread into steel inserts and then there is the negatiive steel stud on the passenger side strut tower.
In the trunk all the ground points are aluminum studs which are similar to the X350 and X358 cars. They look fragile but in my car are in good shape. There is no evidence of water or dampness in the trunk.
Old Sep 28, 2025 | 12:02 PM
  #33
Six Rotors's Avatar
Default More Grounds
I have attached more pics of the grounds in my car.
Drivers side engine ground as found
Cleaned up ground
Cleaned up ground
Drivers side trunk grounds--just like X350 type
Passenger side trunk
Kwayray1
Oct 26, 2021 04:40 PM
Boo
Feb 23, 2019 12:13 PM
Jesse James
Feb 21, 2019 04:45 PM
niceguy753
Nov 9, 2014 11:31 AM
tc1728
Aug 13, 2014 10:57 AM
