XJ ( X351 ) 2009 - 2019
Not happy with in control apps at all
Old Jun 10, 2018 | 02:49 PM
Dela's Avatar
Default Not happy with in control apps at all
What is this nonsense? When I connect the phone through in connect I can only play music on the phones 'hard drive' can't access any other music apps, can't use bluetooth and the music plays through the phone - not the car...
Any updates coming on this? Really surprised at how poor this system is set up
Old Jun 11, 2018 | 02:56 PM
Langstraat's Avatar
What apps are you trying to connect to?
When you say you can connect and use the phone’s music library is that only through the wired connection?
Have you paired the phone to the car?
So many questions which your dealer should be able to sort out.
Old Jun 12, 2018 | 08:09 PM
Dela's Avatar
Paired phone with Bluetooth - that works fine.
But the in control is lacking - I'd like to have my full media player available. I have Pandora, Apple Music, Tidal, Amazon Music - but can only play what's actually downloaded on my phone - annoying.
Apple Car Play MUCH MUCH better
Honestly I'd like to be able to plug into USB to charge and control the phone - but can't - whatever
#FirstWorldProblems
Old Jun 13, 2018 | 07:04 AM
Langstraat's Avatar
Without knowing which model and year of your Jaguar it sounds as though a CarPlay tuner is required to fulfil your needs
Old Jun 13, 2018 | 09:37 AM
XJsss's Avatar
Also the USB plug is in the center console compartment.
Old Jun 13, 2018 | 12:07 PM
JagGate's Avatar
This is by design. When plugged in the car's USB it assumes you want to play direct. Get yourself a power outlet car USB phone charger and use that for charging. This isn't just Jag that does this.
Old Jun 13, 2018 | 12:16 PM
molotov369's Avatar
InControl Apps is pants. I don't bother using it at all. I stick with bluetooth audio.
You can turn off the app autostart though I can't remember how, this would prevent it happening whenever you plug it in.
Shane O' Donovan
Feb 22, 2018 04:44 PM
Nuno Melo
Jan 7, 2018 01:06 PM
nealeholl
General Tech Help
28
Dec 1, 2017 07:04 AM
coffeerich44
XE ( X760 )
Mar 3, 2017 03:37 PM
lungib1702
Jan 20, 2014 10:43 AM
