XJ ( X351 ) 2009 - 2019
Oil Leaking From Oil Cooler?
Old Jun 1, 2024 | 08:51 PM
JaguarXJL15's Avatar
Default Oil Leaking From Oil Cooler?
I think my oil cooler might be leaking oil
Is it possible to tell if its the cooler leaking or the gasket?
Old Jun 1, 2024 | 09:19 PM
Don B's Avatar
I can't recall a report of the oil cooler leaking, so it is almost certainly the gasket (Part 3). You should also replace the two coolant O-rings (Parts 2 & 6):
When the engine is running, pressurized oil can squirt out against the block and heads and splash back onto the cooler. The oil runs down from the sloped sides of the block and heads into the valley, but splashed oil collects on the horizontal flange of the cooler.
Cheers,
Don
Old Jun 1, 2024 | 11:29 PM
Six Rotors's Avatar
Most likely the gasket. Any oil leaking from the cam covers into the V?
Old Jun 3, 2024 | 04:24 PM
I'm not sure I think I saw some oil on the left valve cover but nothing from the right valve cover
Old Jun 3, 2024 | 04:27 PM
Cheers,
Don
Thanks is knock sensor failure common? dealer wants $120.00 each so I would rather not replace unless its common failure
Old Jun 3, 2024 | 09:08 PM
Replaced the cooler gasket today could not see anything wrong with
I did have coolant pour out and go into the engine now I will have to change the oil
the new one left side old one right side
Old Jun 3, 2024 | 11:35 PM
Don B's Avatar
I can't say that I've heard of many KS failures on the 5.0L engines, but while you're there it's definitely worth thinking about. I believe the original knock sensors are by Denso. Rock Auto has NTKs for about $21.00 each plus tax and shipping...
Cheers,
Don
Old Jun 4, 2024 | 04:25 PM
Cheers,
Don
Thanks again I forgot about checking on RockAuto
Do you know the torque specs of the oil cooler ?
Old Jun 4, 2024 | 04:30 PM
The oil leak could be from the valve cover or Oil Filter Adapter Gasket / O-Ring
Old Jun 4, 2024 | 04:48 PM
Don B's Avatar
I don't have the Workshop Manual on this computer, but you can download it at the post below from Graham:
X351 Workshop Manuals & Electrical Guides
Cheers,
Don
Old Jun 4, 2024 | 04:52 PM
trkyam's Avatar
if your valve cover gasket was never changed you are approaching the 10 year mark, and that is usually the first
to leak. I would clean that area thoroughly and re-inspect
Gasman2
May 7, 2024 06:45 AM
JACKP
Mar 22, 2024 03:07 PM
Darren Trapps
XE ( X760 )
Jun 21, 2023 08:47 PM
MudDog
Nov 28, 2022 07:45 PM
creativebush
Feb 1, 2015 12:09 AM
