XJ ( X351 ) 2009 - 2019
P0430 Catalyst Bank 2 low efficiency/ Yellow Restricted Performance
Old Apr 30, 2019 | 01:12 PM
Darealwoody's Avatar
Default P0430 Catalyst Bank 2 low efficiency/ Yellow Restricted Performance
My car has a random misfire (new plugs and ignition coils) and a cat code on bank 2. If I clear the codes and drive like a granny, no issues!!!!! But when I put my foot in it....yellow restricted performance pops up on the screen.... BUT PLEASE HEEEEEEELP MEEEEEEE
Old Apr 30, 2019 | 02:13 PM
XJsss's Avatar
Have no idea of what you are driving. Like what make model year engine. PLEASE HELP US HELP YOU!!!
Old Apr 30, 2019 | 02:29 PM
I have a 2011 XJL 5.0 none sc
Old Apr 30, 2019 | 03:39 PM
XJsss's Avatar
So you have a 2011 5L NA engine. What oil do you use? How many miles on the XJ? Do you use "Top Tier" rated fuel?
Old May 1, 2019 | 04:28 AM
dennis shew's Avatar
Default Jaguar xj8
I have a 2001 jaguar xj8 it needs a load part breather hose in the engine i could use some help.
Old May 1, 2019 | 09:37 PM
Nedoerr's Avatar
First off, big disclaimer, I’m not a mechanic. So take my thoughts with the appropriate grain of salt.
My best understanding of the issue is that the cat code you have occurs when the car checks the upstream (of the cat) o2 sensor and compares it to the downstream (of the cat) o2 levels. If a fault threshold is exceeded it results in a fault. As there are only 3 parts (upstream sensor, downstream sensor, and cat), I would narrow the search to these three items. If you can live monitor your sensor voltages on this bank you might be able to determine whether they look normal or not. I’m not sure how the misfire plays into this. My understanding is that this fault is supposed to tell you your cat isn’t functioning properly.
Is the misfire registering a code, or is it something you feel?
Hope that helps.
Old May 1, 2019 | 09:44 PM
My codes are misfire on cylinder 2,4,6,8 all on bank 2 and the cat code low efficiency on bank 2
Old May 1, 2019 | 10:02 PM
Nedoerr's Avatar
sounds like the fuel rail/ injectors needs replacing. Several members have had this issue causing misfires on all cylinders. I’m sure they will be able to tell you all you need to know.
Old May 1, 2019 | 10:05 PM
Nedoerr's Avatar
You may want to try using fuel injector cleaner first. BG44K gets good reviews (buy online), but you can also try Techron concentrate (Costco/ Walmart).
your cat is probably overwhelmed by the fuel and air due to the misfires. So it is likely secondary to the misfires
Old May 1, 2019 | 10:12 PM
I purchased bg44k today haven’t used it yet. I know Audi newer models have issues with DI fuel systems due to build up on the tip of the injectors and bg44k fixes it. I hope it works for mine
Old May 1, 2019 | 10:18 PM
Nedoerr's Avatar
Good luck; let us know how it goes.
BTW, it’s generally advised to use BG44K or similar injector cleaner every 3-6months to prevent injector problems. It is well worth it.
Old May 2, 2019 | 08:49 AM
Brutal's Avatar
Fix the misfires and yes probobly injectors. The misfires are killing your cat and why its going rest perf. Because its severe enough to cause damage. After misfires are fixed you may or may not need to replace cat but youll need to see if the code even comes back after repair. Misfires are the #1 cat killer. I can get you a 4 pack of oem injectors for $320 pm if interested
JaguarJacks
17
Jul 22, 2019 08:49 PM
Darealwoody
Nov 4, 2018 03:09 PM
KenAdamson
34
Jul 4, 2017 11:27 AM
darren-talbot
Dec 13, 2012 07:57 PM
WhiteXKR
Apr 3, 2012 08:25 PM
