XJ ( X351 ) 2009 - 2019
Parking Brake Fault :(
Old Nov 4, 2019 | 07:23 AM
NvmyJag's Avatar
Since the XJ does not automatically apply the EPB like my old 2005 STR did when you turn off the engine.
How do you guys remember to set it?
I'm not sure what year it changed but my 2016 automatically applies the EPB wheres my 2012 did not.
A picture from this mornings start-up. Ignore the km, hadn't reset it from having the dealership perform updates last Friday.
Old Nov 4, 2019 | 11:33 AM
clubairth1's Avatar
Community Influencer
Mines a 2014 and it does not do it. I wonder if this can be changed using the SDD?
Seems kind of pointless to have a fancy car and it does not use the EPB?
Especially when the lower level cars do apply it automatically.
Old Nov 4, 2019 | 03:45 PM
XJsss's Avatar
I believe, the auto EPB feature was added at the 2016 model refresh.
Old Dec 21, 2020 | 11:11 PM
JaguarPwned's Avatar
Wanted to chime in those steps above do not work on my 2007 XJ8, there is no message or indication computer registered the 5 footbrake pumps.
What did work was removing the negative terminal from battery for 60 seconds, replace, and close the trunk. Start the engine and the brake fault went away.
The original issue seems to be caused by low voltage from the battery, being in the winter and car not used regularly. But even after you charge up the battery, the fault won't go away and won't release the brake. So have to do the above.
Old Dec 22, 2020 | 10:19 AM
clubairth1's Avatar
Well this is the X351 forum and you have a 2007 XJ8 so different cars?
sklimii
XE ( X760 )
Jan 11, 2018 06:27 PM
anthony.eckersall
Sep 17, 2014 08:47 PM
Feffman
Motorsports
Sep 1, 2014 09:58 AM
sweatyfox
Mar 9, 2014 09:04 AM
GhostriderXKR08
Jan 14, 2014 05:13 PM
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
