XJ ( X351 ) 2009 - 2019
Power roof problems with 1996 xjs
Old Jun 12, 2014 | 11:08 AM
DBarry's Avatar
Default Power roof problems with 1996 xjs
Hi.... My roof will not retract or close. It just stoped working with no warning. I have checked the switch and its fine, I hooked power up to the motor and the roof will rise and close. So motor is fine, swithch is fine, the fuse for the roof that is nxt to the roof motor is fine. Is there another fuse somewhere.Any ideas?
Old Jun 12, 2014 | 11:25 AM
ChrisArlint's Avatar
Default Battery
Have you tried to disconnect the positive on battery and touch the negative side for about 15 sec. I had a problem with my Jaguar computer would overload then i could not work my front windows or the roof. but after i touch positive to negative. it went back to normal.
Old Jun 12, 2014 | 01:30 PM
DBarry's Avatar
Not sure if this is the best way of re-setting the computer...... what was your year... not sure if there is a "computer " in the 96xjs
Old Jun 12, 2014 | 04:17 PM
Fraser Mitchell's Avatar
Hi DBarry
You're really not in the right forum for a 1996 XJS, so try posting in the XJS forum. If it is a 1996 XJS, it will have the straight six AJ16 engine, or maybe the V12.
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
allenman85
May 10, 2021 03:11 PM
alpecsa
Sep 7, 2015 11:55 AM
