XJ ( X351 ) 2009 - 2019
Radio screen froze on new car
Old Feb 21, 2011 | 11:58 PM
jcamp's Avatar
Default Radio & Nav screen froze on new car Hi Vin Car
Just got a replacement over a week ago and the radio froze, no stations worked on my way to work, I was frustrated as this happened on my previous one.
It came back after I hit satellite , than switched back to radio. It happened 2x already. The 2nd time the automatic mirrors didn't work, I locked it than unlocked it with the key fob and it worked again, than had the same issue with the radio.
I than tried the navigation it said initializing the same exact issue everyone here is complaining about it was a flashback from my old car. After I arrived at work it came back on and everything has been functioning since.
Could it be the Bluetooth interfering? I notice sometimes it's hard for the bt to connect and maybe freezing the electronics.
Any one still having this experience with the high vin cars?
Old Feb 23, 2011 | 10:33 AM
jcamp's Avatar
It's a hi 15000 vin
Old Feb 26, 2011 | 02:19 AM
gears's Avatar
Bluetooh causes my sound to cut out on occassion. Just for a second or so. Trywithout bt phone on and see what happens
Old Mar 3, 2011 | 09:10 PM
austinmartus's Avatar
you may need to have a hard reset done and the MOST network re-synced. If this was not done properly before the car was handed over to you or after any touch screen updates were done the lock up may occur.
If you don't want to go to the dealer you could attempt this yourself if you feel comfortable disconnecting the battery.
Disconnect battery negative cable (10mm socket)
wait 2 minutes
reconnect battery cable in one clean motion no sparks
check operation of radio
-----if ok goto next step
-----if still locked up a hard fault is present and you need to goto dealer
lock doors and move key more than 12 feet away
wait at least 10 minutes
unlock car and start and let idle for at least 2 minutes
lock car and move key away
wait 10 minutes
then check operations of radio -- should be working properly
at this point you will need to re-learn one-touch windows - hold window switches up a couple times audible click head then roll down, hold until audible click is heard.
relearn parking brake - hold brake pedal down and cycle parking brake once up then down
reset date and time
reset radio stations
set navigation search area
good luck, hope it fixes it.
Old Feb 27, 2012 | 02:45 PM
mosticks's Avatar
Default 2011 Sound System Freezes
Having a similar problem - brand new - all sound will go out and Nav just says initializing. Have to shut down the car for an hour for it to come back. Dealer is trying to say it is related to bluetooth and/or Ipod hookup but it has happened with nothing plugged in and nothing paired.
System has been "reloaded" at the dealer once.
I'm ready to return the vehicle...this would never have happened on the mercedes I traded in.
Any solutions?
MJ
Old Feb 28, 2012 | 09:57 AM
Brutal's Avatar
Yep go back to mercedes, everyone knows theyre problem free
take back and have a genrad tester hooked up to the battery and test for proper voltage and cranking amps.
cranking amps are very important and most do not test cranking amp cap of battery. if lower than specd it drops voltage to low and can corupt startup files and preoper module operation. just like you laptop or desktop, arent all these computers great!!!!
Im working on another crashed laptop at owrk since both my laptops and desktop crashed. got one back, desktop has bootkit issues and working through other laptop. which is okay since all the Jags are working great in Houston and Im out of work again. Nice to have a job and not make money
Old Feb 29, 2012 | 04:01 PM
Maybe_XJ's Avatar
Hi Brutal,
I'm not a technician on cars, but my question is, is the problem the OP posted related to a faulty battery then? What would be causing the battery to fail on a fairly new car?
Old Feb 29, 2012 | 05:13 PM
Brutal's Avatar
IT CAN BE, BATTERIES LIKE ALL OTHER PARTS ARE NOT ALWAYS GOOD EVEN NEW OR FRESH OUT OF THE BOX. THEYRE RATED AT 800CCA, AND IF THEY FALL BELOW THAT VOLTAGE DROPS DOWN AND RECOVERY FROM START IS SLOW AND WITH ALL THE CONTROL MODULES (OVER 35) THEY NEED CLEAN UNINTERUPTED POWER. WHEN I TEST AND FIND A FIALED BATTERY, I ALSO TEST THE NEW ONE TOO, 1 OUT OF 10 MAYBE WILL FAIL TOO. GENERALLY ITS LOW CRANKING AMP. JAGUAR IS VERY INCESANT(sp) ABOUT USING A GENRAD TESTER TO FULLY TEST BATTERIES. NOT JUST THE RUN OF THE MILL AT AN AUTOPARTS STORE OR GENERAL AUTO SHOP.
NOW THERE IS ALSO A REFLASH FOR THIS UNIT WHICH HE SAID THEY ALREADY PERFORMED, 1ST STEP IN THIS PROCESS PER JAGUAR. IE THEY WANT THIS DONE FIRST AND THEN IF THERES ANOTHER ISSUE AND YOU NEED TO REPLACE THE UNIT YOU HAVE TO FILL OUT ELECTRONIC PAPER WORK WITHTEST PERFORMED, REFLASHES, SIFTWARE SUED ETC AND THEY WILL OR WILL NOT GIVE PERMISSION TO REPLACE OR OTHER THING DONE BEFORE REPLACEMENT. DONT GO THOUGHT THIER PROPER PROCEEDURES FOR REPAIR, FINE. THEY DEPBIT THE ENTIRE CLAIM FOR THAT RO(REPAIR ORDER) NOT JUST THAT REPAIR. SO AS USUAL ITS NOT JUST A CUT AND DRY FIRST TIME REPAIR ALWAYS AS IS LIFE
Old Mar 12, 2012 | 02:30 PM
mosticks's Avatar
Latest update - they had my car for another 4 days and actually witnessed the problem. Flushed the whole system and reloaded. Picked it up on Friday. On Sunday, after getting gas, when the car was turned back on, there was no audio, no nav and the backup camera stopped working. Unless Jaguar does something dramatic, i will have to go Lemon Law as this is the third time the car has been in since I bought it 6 weeks ago.
I love the car but have no faith that it won't be a problem child.
Old Apr 17, 2013 | 04:30 PM
ggogins's Avatar
Hate to wake up an old thread, but what was your outcome? Did they finally solve your problem?
Old Apr 18, 2013 | 04:34 AM
mosticks's Avatar
Default Audio lock up resolution
After threatening to go lemon law and return the car, they brought it back in for some exhaustive testing. I actually walked through the issue with the regional service rep and that finally got someone to understand how to test for the issue.
They had a donor car set up and moved my components over one at a time and would drive it around until they saw a failure. This took almost three weeks but it ended up being something they referred to as the audio harness which is like the hub where the various electronic devices come together.
Jaguar did right by me and made two payments on my behalf and I had a replacement during the outage. Sill inconvenient but appreciated.
Old Apr 18, 2013 | 08:43 AM
rscultho's Avatar
This is a stand-up thing from Jaguar. Glad to see they not only fixed your car but actually compensated you and provided a replacement vehicle.
Excellent customer service.
BrentGardner
29
Dec 16, 2024 12:13 AM
msdg137
Sep 16, 2015 06:24 AM
EastFalk
Aug 29, 2015 08:22 PM
Jandreu
Aug 29, 2015 07:31 PM
Terrance Williams
Aug 26, 2015 11:50 AM
