XJ ( X351 ) 2009 - 2019
Remote trunk close?
Old Oct 18, 2023 | 10:31 AM
  #81
lotusespritse's Avatar
So are these units available still? The ebay link to the Polish one is showing "Item no longer available."
Old Oct 18, 2023 | 03:53 PM
  #82
Baltobernie's Avatar
This one from eBay doesn't have the foolproof plugs on each end, but eBay would probably honor your return if non-functional. Maybe somebody here has purchased from this vendor and can comment.
If you get one, let us know about your experinece.
Old Oct 19, 2023 | 09:43 AM
  #83
clubairth1's Avatar
Community Influencer
Good find! I had lost track and could not find anyone selling them anymore.
Old Oct 19, 2023 | 04:58 PM
  #84
Thanks. What do you mean by foolproof plugs?
Old Oct 21, 2023 | 09:35 AM
  #85
The original device was sold by Jez, a UK Jaguar enthusiast who has since passed away. His product had color-coded connectors on all leads, which you can see by scrolling to images posted by early adopters. This made for a ten-minute install that couldn't be misunderstood, because the connectors could only be plugged into the correct receptacle. The unit I linked above appears to have wire leads, so some cutting and splicing should be expected, along with the possibility of error.
Assuming the product works as intended, this should not be a deal-breaker, but installation requires some wire splicing skills and a clear wiring diagram supplied by the vendor.
Old Oct 24, 2023 | 09:42 AM
  #86
Phiplex's Avatar
From the very many images posted earlier in this thread I believe it would be possible to create an electrical diagram of Jez device and how it works. Have anyone done that yet and can publish it here? Otherwise I am planning to do that sometime in the future when I get some spare time.
Old Oct 28, 2023 | 04:01 PM
  #87
Phiplex's Avatar
I have now reverse engineered the Jez module based on the images previously published. The function is rather simple. It is basically to create a connection to ground through a tilt switch (yellow wire) at the output (blue wire), sending a signal to close the trunk. This is achieved only when the lid is open (because of the tilt switch) and when a 12V pulse to the input (brown wire) is provided in order to open the trunk, for example when using the key fob.
Info below regarding the used connectors:
The connection to ground through the not used connector pin C4PL17A/4 is a guess, and any other ground can most certainly be used. The tilt switch can probably also be placed elsewhere.
Old Sep 18, 2024 | 10:46 AM
  #88
fatladz69's Avatar
Hi did you manage to make any of these units?
I don't see the polish version for sale
Old Sep 18, 2024 | 11:19 AM
  #89
clubairth1's Avatar
Me neither?
Might be a good product to sell as they were popular when released several years ago?
jomo
Sep 29, 2021 10:40 AM
k847314
Jan 13, 2018 04:44 PM
JagX02
May 12, 2014 01:22 PM
Stevil
Oct 18, 2008 10:38 AM
crittie7777
Sep 17, 2008 04:53 PM
