XJ ( X351 ) 2009 - 2019
Replacing Driver-side Upper Control Arm
Old Nov 10, 2020 | 06:25 PM
gagman66's Avatar
Default Replacing Driver-side Upper Control Arm
On a 2012 XJL SuperSport, is there a simpler way to remove/replace driver's-side upper control arm without remove the cowl, wipers, and other stuff?
I saw a YouTube video with the guy knocking a hole in the cover to access the bolt closest to the cabin. I'll go to independent shop before doing that.
Old Nov 11, 2020 | 11:34 AM
XJ8JR's Avatar
Ha. That's exactly what I did on mine. I just chiseled away at the stupid plastic covering the bolt.
Old Nov 11, 2020 | 11:07 PM
gagman66's Avatar
How big of a whole is needed? Can the plastic be cut with a small Dremel? Can it be seen with the coolant reservoir re-installed? Do you regret doing it?
Labor cost is approx. $400.00 for this one side. I was able to replace the passenger side.
Old Nov 12, 2020 | 01:53 PM
XJ8JR's Avatar
I used a chisel and hammer but you may be able to squeeze a Dremel in there. The coolant reservoir can stay in place, you'll have to remove the windscreen wipers and cowl to gain access. No regrets at all. Why they would purposefully cover that bolt is beyond me. Once you get access, you're on easy street. I found the passenger side a lot harder because of the fuse box being in the way and I didn't know how to remove it.
Old Nov 14, 2020 | 04:29 PM
Tomwhite's Avatar
Hi, Do you need to do tracking after replacing the arm?
Rabs
Nov 10, 2020 06:32 AM
Terrance39
Sep 19, 2020 07:22 AM
Steve06
Sep 1, 2020 02:14 PM
Jag4
May 14, 2017 03:17 PM
Noxparadise
Nov 24, 2012 02:49 PM
