XJ ( X351 ) 2009 - 2019
SC Solid Coupler or Spring?
Old Jun 23, 2024 | 06:15 AM
clubairth1's Avatar
Community Influencer
With the information we now have just forget ALL the aftermarket couplers and get the proper Eaton made one.
Old Jun 23, 2024 | 07:45 PM
JaguarXJL15's Avatar
If his zz coupler seemed fine in terms of fit and quality like he says I don't see what difference the Eaton one will make
He changed the snout and coupler at the same time so we do not know if it was the coupler or the snout maybe the zz coupler was perfectly fine
Old Jun 24, 2024 | 08:45 AM
clubairth1's Avatar
Then install the one you want?
The facts are in and you can ignore them if you wish?
Old Aug 19, 2024 | 10:25 AM
Originally Posted by GaiaXF-V8S
I just posted this over on the F-Type forum, hopefully it will help here.
I replaced mine on my old XF with updated Eaton part after reading the trouble that the GM LSA guys were having with ZZP and other aftermarket isolator makers. Using the official Eaton part, mine was quiet after replacement and I didn't hear a peep out of it after putting 60K miles on it. Tons of reports online of people replacing their isolators and then having noise develop. Some report noise right away after repair others report the noise developed over time.
Here is the forum where they talk about using aftermarket couplers and the sound going away after moving to the official Eaton part. 4th post down the page.
https://www.g8board.com/threads/lsa-...etness.280901/
I also found this video while getting the direct link to their part. Eaton has a good video showing counterfeit versions of their product floating around, but more importantly they show how solid of a joint their updated coupler makes.
https://www.youtube.com/watch?v=24s0LwxSGKY
Eaton Supercharger Isolator:
https://superchargersonline.com/prod...-engine-09-14/
They use the exact same Eaton TVS1900 supercharger so don't be alarmed that this is for GM cars.
Hope this helps!
When installing this EATON coupler does it require lubricant like the spring coupler or no? dry install?
Old Aug 19, 2024 | 11:06 PM
Originally Posted by dennis black
The solid one I purchased fits snug and tight, I have 2000 miles on it and silent as a lamb
https://youtu.be/7sm3trlw-qI?si=-V9TwPJDt_FVxzlX
Did you use any lubrication when installing the solid coupler ?
Old Aug 20, 2024 | 10:02 AM
clubairth1's Avatar
I want to thank GaiaXF-V8S again for his great and in-depth thread on the proper Eaton solid coupler. I learned so much from his one thread!
I have the Eaton solid coupler and will install it when I have things apart.
That Eaton video just goes straight to the heart of this problem and totally explains the issues and the solution.
Well done!
Old Aug 20, 2024 | 10:06 AM
Well done!
One thing to note the Eaton coupler does not fit aftermarket snouts only the OEMs I tired its too small for the aftermarket fits the OEM fine
Old Aug 21, 2024 | 07:40 AM
  #28
clubairth1's Avatar
Interesting?
I have never seen an after market snout? Only JLR ones?
Do you have a link? Those might be a good bit cheaper than the official ones? But if they are not exactly the same as the stock Jaguar ones that would be a BIG problem?
Old Aug 21, 2024 | 09:11 AM
Interesting?
Looks exactly the same and works with the spring coupler but not the Eaton coupler I went back to OEM
They are sold on Amazon you can get the OEM off of eBay for same price or even cheaper so don't bother
Old Aug 22, 2024 | 10:01 AM
  #30
dmchao's Avatar
@clubairth1 Yes the LSA coupler offered by Eaton is sold by Supercharges Online. It will fit any TVS1900 in the V8s. The V6 aftermarket solid coupler for the V6 supercharger can be found here https://www.ebay.com/itm/12537909232...Bk9SR-jI9af_Yw
The issue is not just with the original non solid spring style coupler. The spring is made of a harder metal than the input shaft. The spring wears deep grooves into the input shaft changing the torsional vibration thus causing unpleasant noise. Eventually all TVS1900 owners WILL develop noise that sounds like marbles rolling around or a can of rocks sound at idle that goes away with engine RPM and a noticeable clunk on engine shutdown. This has been discussed all over forums anywhere the TVS1900 is used. ZZP, LPE and a few other aftermarket solutions have hit the market with mixed results. The Eaton solid solved the issue on mine with no noise even after 60K miles as well as many other TVS1900 owners. It has been a while, but last I checked, I could not find anyone who replaced their noisy coupler with an Eaton solid and have had any further issues. Brian at Superchargers Online, if he is still with them, can answer more technical questions. There is talk of bearing wear if it is ignored for too long due to increased torsional vibration. If you don't have the noise yet you are more than likely safe from more serious issues. On my '13 I will probably have my supercharger ported as well as a new input shaft and solid coupler put on as well as a litany of other upgrades including FI Interchillers Interchiller solution for combating heat soak beyond what an intercooler can do. If you haven't seen Gasman2 post on the F-Type forum about this mod I highly recommend looking into it. Anyways, in my opinion its the best way to ensure the supercharger never has a problem again due to the original issue.
Sorry for the length, hope this helps!
I had heard that the vacuum actuated superchargers have a different thickness than 13+ electronic actuated. I would like to use a solid coupler but I have not seen any forum members do this, maybe I've missed it.
Old Aug 22, 2024 | 12:08 PM
  #31
clubairth1's Avatar
Your right about the change in actuators and I can't answer if it changed the coupler? I don't think it did as all the listings I have seen from Eaton just list the TVS1900. Whether it was installed on a Cadillac or a Jaguar it's the same blower.
Anyone know of any differences?
Old Aug 28, 2024 | 03:32 PM
  #32
dmchao's Avatar
I believe the thickness is different but I feel like the only one with a vacuum actuated bypass supercharger that hasn't changed over to the Eaton solid one. I may not be looking hard enough on the LR/Jag forums.
Old Sep 10, 2025 | 02:57 AM
  #33
Haalex's Avatar
Originally Posted by lotusespritse
I used the highly touted ZZ Performance coupler. It seemed just fine in terms of fit and quality, but I had problems. I guess the snout could have coincidentally been on its way out, or the ZZP coupler stressed the coupler. I don't know. But no more noises from the supercharger while running after putting on a new OEM replacement, so at least the supercharger itself wasn't damaged. That would have been a $3-4K DIY fix.
What OEM reference did you use?
My coupler has a couple of mm of play and makes a buzzing sound most of the time. Looking to replace it for something reliable. I might make a thread about it once the diagnosis is confirmed (i.e. after I've ran the engine without the SC belt).
Old Sep 10, 2025 | 10:09 AM
  #34
lotusespritse's Avatar
I bought the whole OEM snout replacement which includes the OEM coupler because I was worried the snout was damaged by the ZZ coupler. It probably wasn't, but the snout had a lot of miles on it and I didn't want to keep pulling the supercharger to find out the hard way.
JaguarXJL15
Jun 24, 2024 11:22 PM
adent
May 20, 2023 07:07 AM
Vonnslingo
Jan 16, 2022 07:52 PM
adenshillito
Apr 16, 2021 10:01 AM
Frog
Mar 9, 2011 11:55 AM
