XJ ( X351 ) 2009 - 2019
Strange vibrations at idle
Old Aug 29, 2022 | 07:05 PM
  #41
Nedoerr's Avatar
If you hook up to a scanner with mode 6 it will tell you how many misfires you have per cylinder after startup. That could help you determine if it’s a mechanical issue or just an NVH issue.
Old Aug 30, 2022 | 06:05 PM
  #42
VinceCh's Avatar
Originally Posted by PL97
Hmm, just ordered BG 44K and going to use for my next fill up. hopefully it helps
BG 44K works great. I've also had excellent results with Red Line SL-1. Different formulations may provide different results.
Vince
Old Sep 9, 2022 | 10:35 AM
  #43
PL97's Avatar
Just used BG44K in a 75% full tank. Within the first 100 miles of driving, the car felt noticeably smoother. The rough idle/stumble is still the same intensity at idle/park. Guess I'll find some time to bring it to the dealer for diagnosis
Old Sep 12, 2022 | 09:03 PM
  #44
PL97's Avatar
Did an oil change today and rough idle smoothed out about 30% give or take. Vibrations are still there but definitely less noticeable. Still had 1/4 tank with BG 44K in it when I filled up today so not sure if I'll see any more improvements with this tank of gas
Old Oct 25, 2022 | 07:36 PM
  #45
PL97's Avatar
Update, took the Jag to the local dealer and they said the car isn't misfiring, air fuel system are all rock solid. Most likely issue with one of the mounts but they couldn't find the faulty mount after initial inspecting. Car isn't showing any codes from their diagnostic system (aside for my broken front roof shade) They recommended if I could live with the vibrations just keep it as is and come in if it ever got worse or I could pay for them to do a thorough inspection to identify the culprit. Currently keeping it as is since its only noticeable when I'm stopped. Glad to hear that I'm not having any misfires or engine problems
Old Oct 27, 2022 | 08:26 AM
  #46
dmchao's Avatar
If the engine mount really starts to lose fluid, you'll notice the "ribs" on the intake start to sag assymetrically. I.e. the side your mount is sagging on, looks pinched or pushed together.
The dealer kept telling me, it could be a variety of reasons, and truthfully it could be. But it was the motor mount, like I told him xD
irh007
Aug 30, 2025 05:00 PM
a6kmita
Jul 27, 2017 09:39 AM
NTL1991
XJ40 ( XJ81 )
Jan 23, 2016 06:05 AM
XJ8JR
Sep 19, 2014 04:05 PM
L80ous
Jul 13, 2014 12:53 PM
