XJ ( X351 ) 2009 - 2019
Super Charger Noise
Old Nov 19, 2018 | 09:48 PM
silentdub's Avatar
Default Super Charger Noise
Hey guys, I am getting rattling noise on the top rear part of the supercharger, it is just to the right side off the center. On cold start I hear the timing chain tap a little until it warms up in a few seconds but the supercharger noise remains.
I am going to drop the belt tomorrow and see how it feels turning by hand but wanted to reach out since I know I am not the only one with this issue.
The vehicle has 85K miles on it.
Anyone have a Link to a shop manual or TSB?
Old Nov 19, 2018 | 09:51 PM
silentdub's Avatar
Pics
Old Feb 20, 2021 | 05:21 PM
Quietgiant's Avatar
Originally Posted by silentdub
Pics
Did you correct the rattles in your super charger 3 years ago? Mine is doing the same thing. I’m guessing there’s an internal plastic cam and broken spring that is hanging loose.
Old Feb 21, 2021 | 09:59 AM
clubairth1's Avatar
Community Influencer
Remove the SC belt like he suggested. Then start the car to see if the noise has changed or gone.
Also move the SC pulley back and forth with the belt removed to see if it clunks.
Pretty common and I think all of them will eventually make noise.
Old Feb 22, 2021 | 12:02 PM
Quietgiant's Avatar
Thanks.. I’ll attack that issue when I get to the water pump.
Regards
Old Feb 22, 2021 | 08:14 PM
clubairth1's Avatar
Yes that is an excellent time to tackle it. You are right there anyway.
But you can be sure it probably needs fixing and the solid coupler is the way to go if you don't want to mess with it again in the future.
I would order the solid version and be ready to change it. I would also suggest an oil change for the SC since it has to come off for the coupler work anyway.
Old Feb 23, 2021 | 11:36 AM
Quietgiant's Avatar
Thanks again for the input. I’ve ordered the solid coupler and some SC oil.
kiddhan625
Feb 4, 2020 03:01 PM
Johnnyxk120
Jul 29, 2018 08:04 PM
Eldridge
Apr 1, 2016 02:20 PM
RSsteveH
Sep 25, 2013 02:17 PM
mrdobsie
Apr 14, 2011 02:00 PM
