XJ ( X351 ) 2009 - 2019
Tech Info
Old Nov 4, 2011 | 10:26 AM
Fire34609's Avatar
Cool Tech Info
Anyone know of step by step info on removal of door mirror or door panel? Doing some carbon fiber wrap and want to do mirros, but since they rotate can be tricky.
Thanks in advance,
Fire34609
Old Nov 5, 2011 | 09:33 PM
Fire34609's Avatar
Sorry, just realized that I for info about my car. 2011 Jaguar XJ Stratus Grey.
Old Nov 6, 2011 | 08:11 PM
jaglover922's Avatar
There are a few torx screws that have to be removed look carefully around the door. The Wood trim that runs the length of the door has to come off too. There is a 10mm bolt behind it that has to come off. There firmly remove the door panel. There are metal clips at the top of the panel, then plastic clips around the panel. Remove the latch cable from the latch, then the electrical connectors. Reverse the disassembly.
Old Nov 6, 2011 | 10:17 PM
Fire34609's Avatar
Jaglover92, thanks I will give it a look this week.
Old Mar 7, 2015 | 01:21 PM
micheal066's Avatar
I realize this is an old post but I recently had a coworker slam my door so hard that it broke something off inside and now has a rattle. I'm trying to remove the passenger door and got it all the way but one spot behind the wood that's not letting the door panel come free. I'm pretty sure the wood panel has to come off but I don't want to just pull on it and in case it cracks. Is there a trick to removing this? Any insight or pictures would be a huge help.
Thanks,
Curtis
Old Mar 8, 2015 | 11:36 AM
jaglover123's Avatar
Bought subscription to Topix. Might as well share it with you. Hopefully you can take something from it.
File Type: pdf
Old Mar 8, 2015 | 09:38 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
I'm still trying to teach my grandchildren my XJL isn't a pick-up truck or an SUV piece of crap, so their isn't any need to slam the door, but bad habits are hard to break, especially among teens.
Old Mar 9, 2015 | 01:03 PM
micheal066's Avatar
jaglover123 thank you so much for that .pdf! That is exactly what I was looking for. I spent 4 hours Saturday but couldn't figure out the wood panel. I was afraid if I pulled to hard it would crack.
Old Mar 10, 2015 | 11:28 AM
micheal066. Not a problem at all mate. Can you take some picture while you are at it? Im trying to take off the panel but don't know where to start. I have a rattle as well coming from the door.
Old Mar 10, 2015 | 03:05 PM
polarisnavyxj's Avatar
Thanks in advance,
Fire34609
Are you wrapping your own carbon or are you having it done somewhere...
please keep us informed on how it turns out as I may be a client for the procedure if it comes out good.
King Charles
Oct 16, 2015 01:25 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
mrplow58
Sep 30, 2015 08:56 AM
Rocky15
Sep 28, 2015 04:59 PM
