XJ ( X351 ) 2009 - 2019
Trouble programming garage door buttons
Old Jan 31, 2011 | 02:17 AM
jaguarman's Avatar
Default Trouble programming garage door buttons
Hi,
I dont seem to be able to program these buttons. I have many other cars and have never had an issue. I have a rolling code door, I pressed the button on the main unit and then held down the key I want to program, 3 times (after I cleared them out)
Anyone else have this issue?
Old Jan 31, 2011 | 07:18 AM
MiaXfsc's Avatar
Originally Posted by jaguarman
Hi,
I also have a rolling code garage door opener and here is how I programed mine.
1: clear the codes in the car
2: program the car button you wish to use with the remote control from the garage door opener as stated in the manual.
3: press the button on the garage door opener and then press the button on the car 3 times as noted in the manual.
I had similar trouble programing mine also the key was to program using the remote control from the opener first then programing with the main unit second, the manual was not very clear on this.
Old Jan 31, 2011 | 09:20 AM
another_geek's Avatar
Better instructions can be found on the Homelink website here
http://www.homelink.com/program.php
I think the step you are missing is after programming the button in the car, you need to press the learn button on your garage door opener itself and link it to the button in your car.
Old Jan 31, 2011 | 11:55 AM
jaguarman's Avatar
Thanks!
Yes I didnt use the remote first...Ill try that
overall I think the manual is very weak for the car -
Old Jan 31, 2011 | 12:23 PM
gears's Avatar
Don't feel bad. I did the exact same thing and made the same mistake. And I used both instructions until it clicked in my head. And I programmed a lot of those. Not sure why I had a mental block this time.
Old Mar 12, 2011 | 09:23 PM
Rae's Avatar
Rae
OUTSTANDING!!! Just went to the link provided by another_geek, and programmed both garage doors to the xj8 in less than 10 minutes. And yes, I did have to press the learn button on the openers Had been suffering for a few years swapping out hand held remote. No more though. The F-150 is next. I've got to catch up to the technology age......
Old Mar 12, 2011 | 09:30 PM
PaulB's Avatar
I didn't have any luck learning the hand held garage remote but when I pushed the learn mode on the operator it worked right away.
Old Mar 12, 2011 | 10:20 PM
Glendoramike's Avatar
I thought that my Jag wasn't getting the link installed. Then, I found that I have to hold the button down until the door responds. It ain't a quickie!
Old Jun 5, 2013 | 07:14 AM
Adlerwilson's Avatar
Sometimes it happens and then we feel what a crap it is as i also went through this situation and got solution from lot efforts.http://www.aqualitygaragedoors.com/
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
kevinl
Oct 31, 2019 06:15 PM
perfectson
Oct 6, 2015 06:40 PM
sadepol01
Sep 11, 2015 05:26 AM
