XJ ( X351 ) 2009 - 2019
Wheel nut problem
Old Oct 8, 2025 | 11:42 AM
JoshMcMadMac's Avatar
Originally Posted by Don B
For clearance purposes, wrench and socket openings are actually larger than the fasteners they are designed to turn, and vary due to manufacturing tolerances.
As the ASME B18.2.2 Wrench and Socket Openings for Hex and Square Nuts chart below shows, a 3/4" socket can have an actual opening of 0.755" to 0.763", or even larger if the socket is worn.
Cheers,
Don
Correct, and similar tolerances apply to the metric equivalents in B18.2.4 (although they do not specify the wrench).
Either way, for an adapter that's going to be used with a stock lug wrench the ¾" is a negligible variance.
Old Oct 8, 2025 | 01:01 PM
Don B's Avatar
The metric wrench opening tolerances are given in International Standard ISO 691. Yes, the differences between metric and inch-fractional sockets seem small, but they are real and significant when compared to the thickness (thinness) of the stainless steel caps on the original Jaguar lug nuts. Only a little extra play in the socket can contribute to deformation or spinning of the cap.
We have decades of reports of owners damaging their stainless steel-capped Jaguar lugs by using incorrect sockets. So it's important that the information we share in the forums be consistent with Jaguar's specifications rather than the "close enough" claims of aftermarket lug nut sellers.
You obviously know how to judge the fit of your sockets on your lug nuts, but not every owner does, so it's best that we share the most accurate information.
Cheers,
Don
Bikergonebald
Nov 13, 2023 12:13 AM
J_C_R
Jun 29, 2022 01:07 PM
Englishphil XF
Jun 19, 2021 08:44 AM
xjtony
Dec 7, 2020 05:03 AM
Jagisbest
Jul 24, 2017 09:33 AM
