XJ ( X351 ) 2009 - 2019
winter wheels and tires on 11 xj sc
Old Oct 31, 2014 | 08:26 PM
FirehawkMike's Avatar
Default winter wheels and tires on 11 xj sc
I have a set of 19" wheels coming that I intend to mount winter tires on for my 11 xj sc.
First question looking for the ford part number for the tpms so I can get the correct ones cheap.
Second, do I need to run staggered front and rear sizes like the oem summer setup or can I run the same size on all four corners.
Old Nov 2, 2014 | 08:51 AM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
Originally Posted by FirehawkMike
I have a set of 19" wheels coming that I intend to mount winter tires on for my 11 xj sc; do I need to run staggered front and rear sizes like the oem summer setup or can I run the same size on all four corners.
In the '11 XJ Owner's Handbook, on p. 152, "USING WINTER TIRES: When fitted, winter tires must be fitted to all 4 wheels."
"APPROVED WINTER TIRE SIZES; Front: 245/45R19 102V Pirelli Sottozero Series II; Rear: 275/40R19 105V Pirelli Sottozero Series II."
"WINTER TIRE PRESSURES; Front: 32 psi, Rear 32 psi."
While personally I wouldn't feel obliged to use the brand tires Jaguar approved, I would stay with the tire sizes and pressures they recommend. I assume they didn't specify different sizes front and rear, be they summer or winter type, just for the hell of it.
Old Nov 3, 2014 | 08:54 AM
John, thanks never thought to look there.
still need part number for the tpms
Old Nov 3, 2014 | 08:02 PM
Quebecjag's Avatar
[QUOTE=FirehawkMike;1091594]I have a set of 19" wheels coming that I intend to mount winter tires on for my 11 xj sc.
I just put Bridgestone LM-32 on my XJL 2014. Great performance and much more confortable then the pirelli. I will see in the snow and on ice but they are suppose to be more performant then the pirelli. The rubber is softer.
Guy
Old Nov 3, 2014 | 08:10 PM
Just remember, regardless of the tires you select, you have slightly less than 4 inches of road clearance; much more snow than this this will leave your vehicle sitting atop the snow with all four wheels spinning to no avail.
Old Nov 3, 2014 | 08:17 PM
Quebecjag's Avatar
Jonh, I live up north in Canada and on the top of the mountain (I'm a skier). With my XJL AWD equiped with 4 good tires, I can get at home with 2 feet of snow on the road with no problem. Snow is mostly AIR...
Guy
Old Nov 4, 2014 | 07:18 PM
Guy
Glad to hear that. Where I used to live, New Hampshire, we frequently got heavy snow with high water content. Compress it and it turned to ice. Enjoy!
Old Nov 24, 2014 | 07:53 AM
GilesGuthrie's Avatar
A number of people have advised me against the Pirello Sottozeros. Apparently they're not very good below -5 deg C. More made for Italian winters I guess!
No personal experience of them, but that's what I'm hearing anyway.
Old Nov 24, 2014 | 01:44 PM
amcdonal86's Avatar
Interesting! Even if I could get through that snow, would I want to? Scraping up the front fascia and such would not be my idea of fun!
H20boy
Dec 24, 2024 03:23 PM
smith356
Oct 7, 2015 06:41 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
