XJ XJ12 ( X305 ) 1995 - 1997
Cylinder 3 misfire
Old Oct 28, 2023 | 06:17 AM
Ivan Hall's Avatar
Default Cylinder 3 misfire
I pulled codes and it said cylinder 3 misfire, also bank 1 cat issue which I assume is caused by the misfire and it being bank one means a bank. But it seems to be misfiring both banks on one cylinder at the exact same time with my hands over the exhaust. These 2 cylinders never fire it seems. All cylinders are getting spark and a injector signal, also all have at least 190 psi. Well, not too sure about injector signal, but the fluke shows it pulses at least .2 volts. My next step is to hit the injectors with straight 12 volts and observe the clicking action, maybe one is stuck.
Old Oct 28, 2023 | 06:32 AM
Ivan Hall's Avatar
Hoping in here I'll find a diagnostic flow chart, plus what you'd expect to find in a service manual.
https://www.mediafire.com/?pp7qlydtsp6sx
Old Oct 28, 2023 | 04:02 PM
Parker 7's Avatar
1988 XJS ?
Old Oct 28, 2023 | 08:06 PM
Ivan Hall's Avatar
Originally Posted by Parker 7
1988 XJS ?
No, fixed it, thank you for saying something.
Old Oct 31, 2023 | 12:51 AM
watto700's Avatar
G'day Ivan,
What caused the problem and how did you fix it?
Cheers,
Jeff.
Old Nov 1, 2023 | 06:25 PM
Ivan Hall's Avatar
Fixed the reason why he was mistaken.
Old Nov 1, 2023 | 06:28 PM
Ivan Hall's Avatar
Originally Posted by watto700
G'day Ivan,
Cheers,
Jeff.
I fixed the fact that he had gotten my car type wrong.
Sgmmiller
Apr 22, 2021 07:33 PM
tjmattingly
Feb 7, 2017 09:14 AM
lmerritt
Mar 4, 2014 02:37 AM
lcotelaw
Dec 25, 2013 08:45 PM
boliversmith
Jun 2, 2011 08:34 PM
