XJ XJ12 ( X305 ) 1995 - 1997
Help with pipe ID in V12 valley
Old Mar 5, 2023 | 04:55 PM
bullittandy's Avatar
Default Help with pipe ID in V12 valley
Old Mar 5, 2023 | 05:00 PM
Doug's Avatar
Part of the crankcase vent system...but I dunno any particulars
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Mar 6, 2023 | 02:50 AM
SleekJag12's Avatar
Andy those are called the full load/part load breather tubes. The small pigtail fitting goes on the intake manifold stub (part load), and the larger fitting of the same hose goes to the main air intake.
I don't fully understand the design here but the idea is PCV. Although there is no PCV valve used. The hoses have restrictors in them. You probably need to transplant these pipes for your install.
I like what you did with the oil pipe feed/gauge feeds.
Old Mar 10, 2023 | 05:35 PM
Excellent! Thanks to you two! (Also, I always forget to check the parts book)
I went digging through my parts and found the originals and reinstalled.
I’m a little uncertain how this setup isn’t a vacuum leak but will trust the original design since the Jaguar engineers are smarter than me.
Thorsen
Nov 17, 2021 04:09 PM
Jim5_0
Jun 20, 2019 04:20 AM
JigJag
May 29, 2019 08:54 PM
orangeblossom
Feb 28, 2015 02:50 PM
Daim
Jun 22, 2014 12:53 PM
