XJ XJ12 ( X305 ) 1995 - 1997
Hot (re)start issue; click, no-crank
Old Jul 24, 2025 | 01:20 PM
  #61
944play's Avatar
The rebuilder (different guy this time) said the planetary gear is stripped. Replacement parts were available only out of Michigan, so it's at least another week until I get the starter back.
NBD. The XJ12 is my only car, but I only put about 1000 miles a year on it.
Old Jul 27, 2025 | 10:08 PM
  #62
olivermarks's Avatar
Why don't you just buy a new starter?
Old Jul 27, 2025 | 11:09 PM
  #63
944play's Avatar
NEW, as far as I know, is NLA unless I went with an aftermarket lightweight (Wosp, Powerlite?) type. The last rebuild was $255. SNG Barratt is the only vendor I could find that purports to have access to reman originals, but on special order for $330, and I'd have to send in my core.
Old Jul 27, 2025 | 11:23 PM
  #64
https://www.jaguarforums.com/forum/x...nt-how-245557/
BOSCHSR9492X (Remanufactured) Remanufactured
Old Jul 28, 2025 | 12:16 AM
  #65
944play's Avatar
^^ Is Bosch reman already.
Appears to be out of stock everywhere.
Old Jul 28, 2025 | 01:49 AM
  #66
watto700's Avatar
G'day John,
There has been a gear reduction starter on my V12 since I got it in 2006 and I've had no trouble with it.
I did have an intermittent no crank problem with it for a while but part of that problem was slightly loose connections on the battery cable between the battery and the starter and alternator. I cleaned and tightened all of those and that made a huge difference. Those loose connections also meant that the battery was not charging properly.
The only other issue was corrosion in the connector under the RHS inlet manifold which was remedied when I replaced that connector completely. No starting issues since.
Cheers,
Jeff.
Old Jul 28, 2025 | 03:46 AM
  #67
944play's Avatar
I am pretty sure the starter itself was always okay.
Jeff,
This is the sad thing: I think I misdiagnosed this problem from the start (pun not intended) of this thread. Chances are, the previous owner needlessly fired the parts cannon too, just for a lack of targeted abrasion.
Oliver,
Thanks for the documentation. That PDF is, and has been, profoundly helpful.
Old Jul 28, 2025 | 07:09 PM
  #68
watto700's Avatar
G'day John,
I initially made the same mistake and thought my starting problem was the starter motor so I took it off and rebuilt it which made no difference. That then led me to investigate the whole electrical supply and control circuitry where I discovered the problems I mentioned above.
As an added extra thrill because my battery wasn't charging properly I blamed the alternator and removed and rebuilt it to no effect. Fixing the wiring issues solved the problems I was having.
They say live and learn but I dunno whether I have learn't much. Hopefully in future I will investigate any issue more thoroughly to find the real cause.
Cheers,
Jeff.
Old Jul 31, 2025 | 10:15 PM
  #69
944play's Avatar
Starter is back in; waiting for exhaust paste to set up before trying it. The new Bendix drive's overrun clutch actually turns by hand in one direction. The previous one didn't, which probably caused the horrible noise and stripped planetary ring.
EDIT: Damn it. The overrun noise is exactly the same. But on the plus side, the car is mobile at least for now, and I seem to have gotten the exhaust well-sealed.
I should have bought a new starter.
Rebeljag
Jun 16, 2023 05:57 PM
Angrycanuck
Aug 4, 2016 12:34 PM
smaunder
Oct 11, 2014 05:27 PM
sjaurora
Jul 31, 2011 08:34 PM
monkamah
Jan 28, 2010 10:28 PM
