XJ XJ12 ( X305 ) 1995 - 1997
Replacing fuel lines
Old Aug 12, 2019 | 12:04 PM
olivermarks's Avatar
Default Replacing fuel lines
Starting a new thread on fuel line replacement and safety for x305's so we can have a clear how-to. My nightmare is fixing something that currently isn't broken and then having a fire, so figuring out how to do it right and making the car safer is the obvious goal.
My previous V12 experience was with earlier versions and I've emailed www.mrinjectoruk.co.uk to find out which seal and filter kit they recommend for the x305. Has anyone already done this and can share the kit number? Steve at Mr Injector is asking me for the number stamped on injector body, he thinks it's 0280150??? I haven't cleaned my engine yet and don't see the numbers anywhere. for the the two top hoses and the hose by the throttle linkage there is already a useful thread with the napa part numbers and discussion of whether to hose clamp or not by sleekjag12 (thanks!!).
https://www.jaguarforums.com/forum/x...-cover-211576/
a useful how to video for earlier V12's
Old Aug 12, 2019 | 06:56 PM
watto700's Avatar
G'day Oliver,
I replaced my fuel line seals and fuel filter not long after I got my car. The fuel filter was easy enough to track down but the seals were another matter.
The filter PN you will find here
https://parts.jaguarlandroverclassic.../brand/jaguar/
The PN for the seals is CBC4720 and they are hard to find. They are a Viton green square section ring and certainly don't look like a round section "O" ring.
I didn't go to the trouble of replacing any of the hoses and have had no trouble for over 10 years.
Cheers,
Jeff.
Old Aug 12, 2019 | 07:21 PM
Lady Penelope's Avatar
LNA1520AA , they are probable Denso brand
Old Aug 12, 2019 | 08:31 PM
Originally Posted by Lady Penelope
Thanks!!
Old Aug 12, 2019 | 08:40 PM
watto700's Avatar
Looks like you'll get your seals here,
https://www.motorcarsltd.com/cbc4720.html
Cheers,
Jeff.
Old Aug 12, 2019 | 09:12 PM
Default seals
Thx yes I saw that link. If I'm going to be brave and remove the fuel rail etc I'd like the whole kit and kaboodle - the filters, all seals rubber and metal etc so when it's back together I didn't miss anything...
Old Aug 19, 2019 | 02:32 AM
SleekJag12's Avatar
The injector O-ring set, also at Motorcars Ltd right next to the pipe seals:
https://www.motorcarsltd.com/jaguar-...or-o-ring-kit/
oooooo
oooooo
I'm not ready to take all that stuff apart yet. But I probably "should" someday.
They also have a good deal on the pin-clips for the undertray, and for the genuine front upper shock bushings.
Old Aug 19, 2019 | 04:03 AM
watto700's Avatar
G’day Gents,
I took my fuel rail and injectors off a few years ago to have the injectors serviced and in the process one of the injector pintle caps came apart and most of it dropped into the inlet manifold. No problem I thought I’ll just remove the manifold and retrieve all the bits but to my horror the inlet valve was open and all the bits had dropped into the cylinder.
All sorts of horrible thoughts crossed my mind such as a complete head off fiasco to taking the spark plugs out and turning the engine over in the hope that the cap bits would blow out the hole. So I sat down and though about it for a while.
I could see the plastic bits, through the spark plug hole, lying on top of the piston.
I ended up taping a piece of plastic tubing to my workshop vacuum cleaner, as a small bore adapter, and poking around through the plug hole and pretty soon had sucked all the offending bits of plastic out and into the vacuum cleaner.
So if when you remove your fuel rail and this happens to you all is not lost.
Cheers,
Jeff.
Old Aug 19, 2019 | 10:57 AM
Originally Posted by watto700
G’day Gents,
Cheers,
Jeff.
Thanks, I bet that got your pulse going!!
Jaguila
Nov 9, 2014 06:01 PM
Jaguila
Jan 20, 2014 08:01 PM
Nos_Monkeys
Jan 16, 2014 10:24 AM
howlinowl
Sep 3, 2012 11:08 PM
plums
Jun 19, 2012 07:06 PM
