XJ XJ12 ( X305 ) 1995 - 1997
V12 Serviced with 5W30
Old Apr 21, 2022 | 04:15 PM
N Bath's Avatar
Default V12 Serviced with 5W30
I have owned my x305 fire about a year, and although normally service my cars myself, took it in to the local Jaguar dealer for a service, thinking it was worth it to make sure everything is all good.
I was really surprised when the used 5w30 oil.
The temperate in in the North of NZ ranges from about -5 to degree’s C, and according to the owners manual I would think 10w40 would be the right oil for that ambient temperature range.
Am I obsessing over nothing? Big deal or not?
Old Apr 21, 2022 | 05:26 PM
944play's Avatar
Let's be sensitive about Jaguar V12s around here....
I would prefer to run a heavier weight than 5W30, but since it is an officially acceptable viscosity at some temps and oils have improved so much since the 6L was developed, it's probably fine.
Old Apr 22, 2022 | 04:25 AM
SleekJag12's Avatar
Like I was saying, about those fuel hoses.... Not such a problem with the 305 yet but with the XJ-S, it is no joke! Lol.
I've never heard of anyone in the V12 business state that 5W/30 is the go-to for it. Did they consult you at all? Was it just the cheapest because you needed 11L? Did they mistake your Daimler Double-Six for an XE 25t?
That being said, I concur with John, it'll probably be fine. It is winter there after all.
*This is not an oil thread.
Old Apr 22, 2022 | 04:59 AM
N Bath's Avatar
They just serviced the vehicle, and when I asked what oil they put in so that I knew what to top it up with, they said fully synthetic 5w30. But I was being picky, so checked the owners manual when home.
They said it’s the same oil that they always use for my model car/engine. There can’t be many x305’s running in NZ, but they do come up from time to time, so they may have serviced them before, I just don’t know.
On the upside, they were complimentary about the car.
Thanks for the reassurance.
Old Apr 22, 2022 | 11:11 AM
olivermarks's Avatar
Maybe Jag thought circulating 11 litres of oil is a big job for the oil pump? I have my sump sandwich plate off and was ruminating on that. As engines get to higher miles travelled we tend to put heavier oil in, but that's a greater load on the circulation systems especially as the crud builds up. My sump plate had a lot of black goop sitting around on it.
I was going to put 10 40 synthetic in but now stroking chin on this one...
Robbo D
Nov 1, 2021 02:15 PM
Crackerbuzz
Jan 17, 2019 02:26 AM
philwarner
Oct 2, 2017 04:47 PM
ron
Feb 14, 2013 01:38 PM
Butch
E type ( XK-E )
Apr 2, 2012 01:56 PM
