05 VDP transmission or engine mount?
Old Jun 21, 2023 | 08:36 PM
Deepstuff's Avatar
Default 05 VDP transmission or engine mount?
Hi,
In my new to me VDP, I feel a bump just as engine starts, and also feel a bump when get into the gas to pass on the highway. I'm thinking engine or transmission mount? What's the usual suspect? My car has 93,000 miles.
Tks.
Old Jun 22, 2023 | 11:16 PM
abonano's Avatar
Could be either but sounds like an engine mount.
If trans mount car would feel movement when going in R from Park.
Old Jun 23, 2023 | 10:42 PM
Panelhead's Avatar
Default Engine mounts
Engine mounts are the easiest to check. With motor running place car in drive and with brake applied increase tpm. That is mount that normally fails. See if engine lifts.
The place in reverse and with brakes applied,raise rpm to check engine movement.
i doubt there is a good check for the transmission mount. Usually change to see if that helps.
Tranny might benefit from a fluid service.
Flex320
XJ XJ12 ( X305 )
Jan 5, 2023 12:12 PM
JagXtypeV63.0L
Nov 28, 2020 07:19 AM
kazi
Feb 24, 2020 08:46 AM
Higgins
Feb 20, 2019 05:50 PM
kyle04
Sep 26, 2013 06:51 AM
