Transmission/Engine mount same?
Old Dec 11, 2019 | 11:37 PM
kazi's Avatar
Default Transmission/Engine mount same?
Can anyone confirm that 07-09 xkr's have the same part number for the rear engine mount and the transmission mount? Part numberXR849534. Dealer wants $185 but when I was searching online I noticed it was being advertised as a rear engine mount and a transmission mount. In pictures the part looks the same. When its being advertised as a transmission mount its about $160 but the ones advertised as an engine mount are under $100. For instance welsh ent. has it for $65 but advertises it as an engine mount. Even different dealer websites have part number xr849534 advertised as both. But no one advertises them as engine/transmission mount.
https://www.welshent.com/Jaguar-Rear...nt-P27223.aspx
Old Dec 12, 2019 | 12:52 AM
Cee Jay's Avatar
Rockauto dot com shows completely different than an engine mount than the Transmission mount shown. I had my engine mount changed a few months ago and it looked nothing like this.
Plus, here's a screenshot at eBay, totally dissimilar;
Old Dec 12, 2019 | 02:54 AM
steve_k_xk's Avatar
Cee Jay is completely correct they are totally different.
I replaced my left engine mount last year I actually snapped it the same night after I swapped my diff ratios.
As my vehicle is a RHD changing the left was straight forward if it was the other mount the steering rack shaft has to be disconnected for clearance.
Old Dec 12, 2019 | 05:11 AM
kazi's Avatar
Sorry i should have specified I was looking to get the transmission mount. It doesn't look like this?
[img]blob:https://www.jaguarforums.com/a64aa300-c4c1-498c-b767-b866b13ebbcd[/img]
Old Dec 12, 2019 | 05:13 AM
kazi's Avatar
Old Dec 12, 2019 | 08:13 AM
gkubrak's Avatar
Originally Posted by kazi
This is the trans mount. I did mine a few weeks ago.
Old Dec 12, 2019 | 10:04 AM
kazi's Avatar
Nice...so did it firm things up for you? Maybe get rid of some clunking or vibrations?
Old Dec 12, 2019 | 11:52 AM
gkubrak's Avatar
Post # 23:
https://www.jaguarforums.com/forum/x...-219958/page2/
Old Feb 23, 2020 | 09:24 PM
jahummer's Avatar
Steve
I am exploring ways of switching to solid mounts. I have not had one in hand and can’t tell much from pictures, but what is the design like? Is it steel or alloy? Could it be welded together at the seams to prevent flex?
Old Feb 23, 2020 | 11:12 PM
Cee Jay's Avatar
It'd probably be easier, cheaper and more reliable to weld two plates on the ends of some heavy wall 3" pipe, have the mounting bolts go through the plate.
Everything is doable with a metal saw, some steel and a welder.
Old Feb 24, 2020 | 02:56 AM
steve_k_xk's Avatar
Originally Posted by jahummer
Steve
jeremy the mounts are liquid filled with aluminium outer casing, in terms of solid mounts I would never recommend them.. think of a Harley Davidson like vibration throughout your entire cabin the rear view mirror would probably fall off from the vibration.
Surely someone like sng Barrett or green racing would have a heavy duty purpose built for tuned xkr's.
Old Feb 24, 2020 | 08:46 AM
jahummer's Avatar
I don't think you can compare a 2-stroke motor to a smooth purring V8...
Solid mounts have been done on many modern cars with great benefit to performance, reduced 1/4-mile times, improved handling, etc. and little increase in NVH.
Sounds like the factory mounts would not likely be good for modifying. I have searched and searched and can find nothing off the shelf that would be suitable.
jigginadeal
May 10, 2024 12:52 PM
steve_k_xk
Oct 5, 2020 06:22 PM
Higgins
Feb 20, 2019 05:50 PM
AlbBolivar
Jun 21, 2015 10:28 PM
martin fothergill
Mar 19, 2010 09:13 PM
