19 x 9.5 rims
Old Mar 29, 2021 | 08:49 PM
Bmicks's Avatar
Default 19 x 9.5 rims
Does anyone know if 19x9.5 rims would fit on 2000 xj8? I know the height would work but have no idea on the width?
Old Mar 29, 2021 | 09:33 PM
scooterforever's Avatar
I think the answer requires a bit more data, namely what ET / positive offset do you expect to be running with 9.5" rim.
- scooter
Old Mar 29, 2021 | 10:14 PM
Bmicks's Avatar
Yes you are absolutely right...the offset is +36mm, I completely missed that!
Old Mar 30, 2021 | 04:59 AM
paydase's Avatar
Normal offset is +49.
So with these rims you would have the external edge of the rim protruding 13 mm + 6 mm (1/4") = about 2 cm more on the outside.
Maybe still acceptable for not rubbing, to be checked.
Depends also on the tires you would install: if keeping 255/40 R19, it should be OK.
Old Mar 30, 2021 | 10:14 AM
Bmicks's Avatar
Thank you for your input!
Marque
Oct 11, 2015 05:59 PM
1badjag
XJ40 ( XJ81 )
Feb 13, 2010 04:15 PM
JWATTS36
Aug 11, 2009 08:20 AM
matl
Jul 16, 2009 06:07 AM
sempaipaul
May 23, 2007 08:36 PM
