2004 XJ8 Climate Control is funky
Old Mar 4, 2024 | 10:18 AM
CGBosn44's Avatar
Default 2004 XJ8 Climate Control is funky
My climate control system is not functioning properly:
It's always on. I can't turn it off by pressing the On/Off blower button.
The blower motor works just fine.
The right side of the dual controls seems to work properly. I'm able to raise and lower the temperature.
The left side blows cold air because it is stuck on 64 degrees. I am unable to change the temperature. In fact, when I push the button to raise the temperature, nothing happens (the numbers do not increase on the display).
Unrelated? The fuel gauge intermittently shows empty when it has more than 3/4 full tank.
Non navigation.
Old Mar 5, 2024 | 01:18 AM
Wingrider's Avatar
No help on the climate control.
But my fuel gauge acted as you describe,
Jet pump sender # C2C31126, Fuel pump sender # C2C31125,
Replaced the actual pump as well.
Bought a Delphi that came with a pre made wiring harness.
That was plug & play for my 04 Jaguar
Delphi Fuel Pump Kit DEL38-K4014 For Ford ... - AD Autoparts
Old Mar 5, 2024 | 02:01 AM
h2o2steam's Avatar
Could be a collapsed button that is effectively staying on and locking up the keypad.
Old Mar 5, 2024 | 06:15 AM
Wingrider's Avatar
If so, ebay has a few available
Old Mar 5, 2024 | 06:37 PM
meirion1's Avatar
The blower runs continuously at low speed and you cannot turn it off
unless you turn all the climate controls off with the top left side button.
Known fault when fuel senders have bad contacts due to corrosion.
Old Mar 6, 2024 | 12:33 AM
h2o2steam's Avatar
Wow.......that is a bizarre effect.....thanks for sharing that nugget.
I wonder how a faulty sender crosses over into the climate control system?
I hadn't come across that issue in my general readings so far on the XJ8.
Old Mar 6, 2024 | 01:57 AM
Wingrider's Avatar
He also mentioned that the fuel gauge.
Was going to empty, when he still has plenty of fuel.
Old Mar 6, 2024 | 10:01 AM
Rickkk's Avatar
Given those symptoms, I don't think that it would hurt to check the earth grounds.
Old Mar 6, 2024 | 03:14 PM
meirion1's Avatar
Mark
I am guessing that the two faults are not connected?
I had a lazy sender briefly many years ago which sorted itself
out. That was in 2010!
Since then a very few people have reported a similar problem.
Bob
Old Mar 7, 2024 | 01:23 AM
h2o2steam's Avatar
Hi Bob,
Thanks for setting me straight on my misinterpretation.
I couldn't for the life of me get my pea sized brain to work out how those two things things possibly tied together.
Old Mar 7, 2024 | 11:02 AM
CGBosn44's Avatar
Thanks for the tip on the fuel pump/sender.
Old Mar 7, 2024 | 11:04 AM
CGBosn44's Avatar
We'll see.
I bought a used climate control dash unit.
I'll change it out when the weather turns warmer in New York.
CGBosn44's Avatar
Thanks for the tip.
Old Mar 7, 2024 | 11:07 AM
CGBosn44's Avatar
I'll check the grounds. Thanks.
Old Dec 16, 2024 | 02:16 PM
CGBosn44's Avatar
Default Repaired. I bought a used climate control unit.
Non navigation.
I bought a used climate control unit. Swapped it out after removing center console bits.
Old Dec 17, 2024 | 03:14 AM
feniks138's Avatar
Any changes?
kiloslanga
Nov 22, 2022 02:52 PM
Bartman
Jan 18, 2022 03:23 PM
ddasilva99
Feb 17, 2011 05:31 PM
Sinister 1
Dec 17, 2010 02:11 PM
KruBruder
Apr 11, 2009 08:43 PM
