2004 XJR HELP!
Old Mar 1, 2008 | 06:33 PM
FactoryJaguarTech's Avatar
Default RE: 2004 XJR HELP!
I would say the air intake is probably the cause. Have seen it a dozen times where the MAFs cannot compensate correctly and causes the lean codes.
That isnt gospel however. If the tech cannot figure it out, tell him to get some help from someone with more experience.
Old Mar 1, 2008 | 08:31 PM
Only way to figure out problem with aftermarket parts is to work backward.
Easiest addon was the airbox. Start there. If doesnt fix, try another mod and reinstall the one that tested ok.
It can be along process and will get pricey as it goes along. I prefer to leave higher end cars as they came specifically due to the problems you are having.
I hop it works out for you.
Also, there is no mapping for your car as such. Some companies have a ECM map program but have heard good and bad.
Old Mar 2, 2008 | 10:15 AM
jag_genius's Avatar
yeah i heard the early xjr just adapts to it by adding fuel... and drives fine.. but i haven't seen it on the newer version 4.2 super.. might half to tinker with the ECT sensor. to make the engine think it is colder so the ecu adds more fuel.. just a idea.. not sure if it will work tho.. if it was mine i wud leave the car alone as FJT said.
Old Mar 2, 2008 | 09:19 PM
The exhaust will be fine and sound good too. As long as the O2 Sensors are still in there, you should have no problems with exhaust only unless the tech installing messed up a sensor. That is unlikely though. I love the Sepang wheels btw. Just a little heavy at the end of the day and you got to do a tire rotation.....lol
Old Mar 2, 2008 | 09:30 PM
The Map sensor on yours is at rear of engine and shouldnt have been anywhere near where they were working.
The mass air flow or MAF is of course possible that it was damaged. Ask the tech to swap it with a known good one real fast to make sure it is ok. Only takes a minute to swap it.
Donzi
Oct 18, 2018 12:26 AM
scooternva
19
Oct 27, 2015 02:14 PM
jhn
Sep 21, 2015 09:43 PM
Donzi
Sep 17, 2015 01:29 PM
jhn
Sep 14, 2015 07:39 PM
