2004 XJR--Info on purchase of used module.
Old Sep 10, 2017 | 02:28 PM
Roc3207's Avatar
Default 2004 XJR--Info on purchase of used module.
My headlights, wipers, windows, glove compartment, and fuel doors buttons are not functioning. I was hoping that it was a blown fuse. However, the mechanic stated that the module needed to be replaced. Mechanic also stated that Jaguar no longer sells new modules for my vehicle and that cannot guarantee that a used module will work. If used module does not work, I'm still out of pocket for module and labor costs. Anyone ever purchased used module?
Old Sep 10, 2017 | 04:18 PM
RDMinor's Avatar
If you know which module it is there are a few services on eBay that repair the older modules for a reasonable fee. Also, most salvage yards give you a 30 day guarantee so if you got a bad one you'd really only be out some shipping.
Jaguar XK Series: Jaguar Used Parts, Auto Body Supplies, Salvage Car Wrecking Junk Yard ...... also XJ8's and R models. Out towards their last 5+ pages they list a ton of modules.
Old Sep 10, 2017 | 07:37 PM
Roc3207's Avatar
Thanks for info. I'm gonna check on which module it is and try to purchase myself.
Old Sep 10, 2017 | 08:41 PM
abonano's Avatar
Check your grounds up front in the engine compartment.
Old Sep 11, 2017 | 11:27 AM
Sean W's Avatar
EDIT - original post a complete miss on my part. I started reading the wiring diagrams from the end point and didn't get to the FEM. Basically I started backwards and stopped too early.
https://www.jaguarforums.com/forum/x...advice-187787/
thank you Bob.
Last edited by Sean W; Sep 11, 2017 at 05:35 PM. Reason: incorrect feedback sent initially
Old Sep 11, 2017 | 05:17 PM
motorcarman's Avatar
I believe the FEM is NLA. You can call a local dealer and inquire if that is the module that the local mechanic thinks is the fault.
Configuring modules to these cars can be 'tricky'. Be sure you understand what modules need configuration and make sure you understand the VID block.
ADMIN TSB 1-186 has info before you start something that requires tools you don't have.
There are discussions on this forum about configuring modules, both successes and failures.
bob
