2005 XJ engine malfunction light
Old Sep 4, 2018 | 06:45 AM
Jurien Ink's Avatar
Default 2005 XJ engine malfunction light
I have a 2005 XJ6 and the engine malfunction light came on a few months ago and then went away. It came on flashing the other day and seemed to lose power for a while then was ok and light went out. Then about 50kms down the road it did it again. I have put a scanner on it and it comes up with P0171 code . Bank 1. I have changed the fuel filter. But it has a noise in the front end when it is idling but not while driving. Can anybody help me. Thanks Barb
Old Sep 4, 2018 | 05:01 PM
JagV8's Avatar
Flashing = severe misfires, causing cat conv damage. Do not keep doing that!
Go air leak hunting - see the many threads about your code.
Old Sep 4, 2018 | 05:24 PM
meirion1's Avatar
Try to investigate the noise when idling since it could be related to the air leak. eg loose or broken hose.
Old Sep 5, 2018 | 09:56 PM
Jurien Ink's Avatar
Thanks mate. Have now taken it to a Jaguar Specialist in Perth. hopefully they will fix the problem without me doing a seek and trial and error. Cheers Barb
Rickkk
40
Apr 19, 2018 03:45 PM
sxiro
Dec 21, 2017 10:20 AM
snhnic
Aug 13, 2017 09:46 PM
wallace
Nov 24, 2009 04:26 PM
mtjagman
Nov 8, 2009 01:31 AM
