2006 Vanden Plas Multiple Problems
Old May 23, 2016 | 01:55 PM
jerryl440's Avatar
Default 2006 Vanden Plas Multiple Problems
Currently the owner of a 2006 Vanden Plas and it has been a great car. All of a sudden the following electrical problems. All these problems happened the same time. 1. Turn on head lights bezel lights around navigation system flashes then goes out. 2. Interior lights inoperative when door opens or try to turn on manually overhead switch. 3. Sun-Roof will not open or close. 4. air-ride will not operate and does not give failure code. 5. Windows will not work. When remote key is pressed and held the windows and sun-roof opened, but will not close when using door switches all four (4) door. When remote key is held in the closed position with key in door Sun-Roof closes, but windows will not. They are stuck in open position. (Car in garage). Taken to dealer and they don't seem to know what it is. Could it be the TPMs.
Old May 23, 2016 | 02:04 PM
jerryl440's Avatar
Default Speakers stopped working also
I almost forgot. The sound system stopped working also. All 4 speakers.
Old May 23, 2016 | 02:34 PM
Fraser Mitchell's Avatar
Sorry Jerry, wrong forum !
Try posting in the X350, X358 forum. You should get plenty of advice.
Old May 24, 2016 | 11:27 PM
nlt624's Avatar
Have your battery checked.
Old May 25, 2016 | 04:53 AM
clifton94's Avatar
Does the car start and run
Old May 25, 2016 | 10:32 AM
harvest14's Avatar
When our 04 XJ8 started giving us random electrical problems it turned out to be a corroded ground connection. I fixed that and everything was fine again.
May not be your problem, but if the dealer didn't check it I would put that on my list.
Old Jun 22, 2016 | 07:22 PM
jerryl440's Avatar
Yes it runs fine. I'm wondering if it could be the BCM Body control module. I cannot find anything in the manual where it's located.
Old Jun 23, 2016 | 01:54 PM
grantorino62's Avatar
How old is the battery? Don't trust it past 4 years. You might remove the cables, clean the posts and reattach. Also the 4 ground studs by each head light could be corroded. Do the cleaning (its free) and report back. I would not buy anything except maybe the battery if it is in fact, over 4 years old.
Old Jun 23, 2016 | 01:55 PM
And.... add your car to your profile!
Old Jun 23, 2016 | 04:20 PM
XJ8JR's Avatar
+1000 on checking the ground studs and battery
Old Jun 23, 2016 | 05:49 PM
meirion1's Avatar
Earths (grounds)
Old Jun 25, 2016 | 11:50 AM
200Volts's Avatar
If you don't have a new battery yet, then attach a charger to the battery. This will supply more than 13 Volts to the system. Don't start the car, but try the sunroof, radio, etc. that don't work now.
I had an XJ8 that would work with less than 12.4V.
Old Jun 25, 2016 | 12:17 PM
Do you mean "wouldn't" work? Good idea assuming its a weak battery, not a loose/ dirty ground.
ericjansen
Mar 30, 2017 06:12 PM
Erhard
May 7, 2016 05:11 PM
Palmero
XJ40 ( XJ81 )
Apr 16, 2016 08:24 AM
Elizabeth Finn
Apr 12, 2016 07:02 PM
Dale Konkol
Mar 30, 2016 08:28 AM
