99 XJ8 ABS Traction Control Module issue
Old Nov 21, 2015 | 01:14 PM
steveyd1's Avatar
Default 99 XJ8 ABS Traction Control Module issue
I get the typical ABS light and stabliity/traction control warning. I have a part#LNC2210AD in the car when I bought it and says rebuilt. I sent it out to BBA and they said it was unrepairable so I bought a repaired unit from them. I put the same model# unit in that I bought from BBA which was a rebuilt. The new unit shows the same faults as the other but now the odometer/speedodometer don't work and the emergency brake light stays on. I returned the unit to BBA and put my original back in. BBA said they tested return unit and it shows good?
Why would all these other faults show regardless. If all of these faults show could the return module have been ok and something else wrong with the car causing fault codes/things not working issue?? Pump# in the car is MNC5920AC.
Old Nov 21, 2015 | 09:56 PM
motorcarman's Avatar
Wrong forum section. You have X308
bob gauff
FDR
May 23, 2016 09:18 PM
FRGIII2014
Nov 18, 2015 04:56 PM
Rick L
Oct 29, 2015 08:18 PM
EZDriver
Oct 26, 2015 02:26 AM
millertic
Oct 25, 2015 08:42 AM
