Air box
Old Oct 23, 2019 | 07:49 AM
rereswood's Avatar
Default Air box
Will the 2W93 9600 AG air box fit my XJR 2004 only really needing the lid or have to be 2W93 9600 BG Thanks
Old Oct 23, 2019 | 09:08 AM
Brutal's Avatar
The lids on 04 na and sc are the same. Its the lower box with electric solenoid operated door for additional air that is different
Old Oct 23, 2019 | 10:59 AM
rereswood's Avatar
Thank you
Old Oct 23, 2019 | 11:58 AM
rereswood's Avatar
regarding the flap is this worth removing ..
Old Oct 23, 2019 | 04:45 PM
Brutal's Avatar
why? It opens when youre getting on it. Just let it function as designed
Old Oct 23, 2019 | 05:32 PM
Panelhead's Avatar
Default My answer to your this common issue.
The lid on my 2006 XJR looked different than the XJ8 lids I looked at. Decided to fix professionally.
Installed an XJR clamping devise to eliminate chance of air leak and future failure of other latch.
These are 60.00 including shipping. 100.00 for two.
Old Oct 23, 2019 | 06:25 PM
abonano's Avatar
As Brutal mentioned the air lid for the N/A 4.2 and SC cars are the same.
Some people have mentioned having issues closing the air lid when fitting K&N aftermarket filters.
I have a K&N installed in my XJR. I make sure the slots in the air lid are fully engaged in the base of the air filter housing before attempting to close the lid.
I also disconnect the rubber hose from the air lid assembly and disconnect the harness as well.
Old Oct 28, 2019 | 04:55 PM
redrover41's Avatar
All you state about fitting a K&N is true. I buggered my air filter box this past summer. Used a bungee cord to keep it closed until I found a used one on eBay.
A bit of silicone grease around the seal and on the tabs/slots helped. I only used the top. the bottom piece is available.
Also, I covered the air intake to the airbox with 1/4" hardware cloth (wire mesh). I found that chipmunks or mice had been nesting in the airbox dragging along acorns and bird seed. Just thought I'd pass this tidbit along.
Barry_Tucker
Mar 18, 2023 07:36 PM
Paulo Santos
Oct 14, 2016 08:21 AM
friscoricky
Jul 31, 2011 12:12 PM
A17EES
Mar 22, 2010 06:33 PM
