Air con not working, pipes are cold
Old Mar 10, 2020 | 04:38 PM
Allycat's Avatar
Default Air con not working, pipes are cold
Hi, i have my car booked in for a regas on the 16th but was wondering if there are any problem areas i can eliminate prior to it. The pipes going into the car are cold.
Old Mar 10, 2020 | 04:59 PM
motorcarman's Avatar
The climate control module might have the answer (DTCs) logged in it so that might save some diagnosis.
Read the codes as a starting point. You might need the repair shop or someone with dealer level diagnostics to read them.
Servo motors drive flaps so it could be that or a faulty temp sensor??
Good Luck
Old Mar 10, 2020 | 05:17 PM
meirion1's Avatar
+1 on the above
Is the heater working?
Is the blower working?
Old Mar 10, 2020 | 06:31 PM
Allycat's Avatar
Good Luck
Originally Posted by meirion1
+1 on the above
Yes the heater and blower are working fine. I have a cheap code reader i have been using to identify my lean codes which may not have the scope to identify a/c issues.
Fortunately i should be able to borrow a friends Carsoft reader. Would the a/c system produce a EML light if there was a DTC logged ? Many thanks for your input :-)
Old Mar 16, 2020 | 03:18 PM
Allycat's Avatar
Air con now cold as can be! Turned out to be a bad pipe connection on the condenser.
gtunstal
May 4, 2018 08:09 PM
martin49315
Mar 30, 2017 04:56 PM
AH101
Jun 15, 2015 12:46 AM
Johnny
May 28, 2009 08:17 PM
