Air Suspension Problems
Old Aug 10, 2018 | 05:57 PM
keelak's Avatar
Default Air Suspension Problems
I ran over something on the freeway and knocked out a fog light that sits in front of the pump and the car immediately dropped. 4 hrs later I unplugged the positive cable and plugged it back in and the compressor came on for less than a minute and was hissing and sounding choked up and it cut off and would not cut back on. I replaced it with a used one and it came on and went right off. Any suggestions
Old Aug 10, 2018 | 06:09 PM
meirion1's Avatar
Sounds like the strut is damaged and leaking.
Old Aug 10, 2018 | 06:41 PM
keelak's Avatar
I really don't think so because I've replaced shocks before. The car was fine until I hit something. I thought the pump my have needed replacing since it is behind the fog lamp. I am so puzzled!!
Old Aug 10, 2018 | 09:02 PM
meirion1's Avatar
You said the car dropped immediately so you have a leak
if not the strut a damaged air line.
Old Aug 10, 2018 | 09:05 PM
keelak's Avatar
You may be right. Thank You for responding and I appreciate your time and input😊
Old Aug 10, 2018 | 09:24 PM
keelak's Avatar
Default Air Suspension Compressor
I just checked it with a diagnostic and it read PO414 Secondary Air Injection Switching Valve A Circuit Shorted.
Old Aug 11, 2018 | 03:28 AM
Partick the Cat's Avatar
AIUI secondary air injection is an engine system, nothing to do with the suspension.
Old Aug 11, 2018 | 03:50 PM
meirion1's Avatar
Superb explanation here:
www.obd-codes.com/p0414
more info here but not X350
https://www.jaguarforums.com/forum/x...33/vic-148427/
AFIK the x350 does not have sec air inj.
Others may know more.
silversurfer1221
27
Sep 27, 2022 02:06 PM
milleniumaire
Oct 1, 2020 05:59 PM
Gregfromuk
Oct 7, 2013 03:03 PM
Jayshmie07
Jul 8, 2012 04:24 PM
MANIACK
May 30, 2012 09:06 AM
