Anybody ever replaced the firewall padding?
Old 02-29-2016, 07:52 PM
Ben7's Avatar
Question Anybody ever replaced the firewall padding?
On my '05 XJ8 L, Standing in front of the engine and looking back to the firewall at the top there is a firewall padding, mine has partially eroded? Anybody ever replaced there's? You can see what looks like push in tabs that keep in place? A couple of my tabs seem to even be missing. (Seem like the XK/XKR doesn't have a firewall pad, so I did specify this is a XJ8 L same engine bay as XJ8).
Old 02-29-2016, 09:38 PM
BlackKat's Avatar
I recently removed the insulation to remove the plastic firewall, when replacing the valley hose. The insulation was hiding some of the push tabs and was also starting to deteriorate. I have yet put back the plastic firewall as it seems I may have to replace the EGR. I haven't really noticed any change in sound deadening or heat creeping in. I am thinking of replacing the insulation, prolly something cheap to cut.
Old 02-29-2016, 10:25 PM
Ben7's Avatar
Curious, what is the valley hose and the EGR and what do they do or function?
Old 03-01-2016, 12:23 PM
hafren's Avatar
Let us know if you find some and pics if possible when you fit it
Old 03-01-2016, 10:01 PM
BlackKat's Avatar
The valley hose is a coolant jose from the block valley under intake and supercharger, connecting to throttle body behind the supercharger. It is a real pain to replace. Intake, throttle body, EGR and supercharger have to come out.
The EGR is an exhaust gas recirculating valve that redirects some exhaust gases into the throttle body to be burner more completely. This can also be used to cool the cylinders. I may have damages mine when I removed it.
Old 03-02-2016, 04:50 PM
Sean W's Avatar
Received 4,188 Likes on 2,348 Posts
https://www.google.com/search?q=fire...sAQIVw&dpr=1.5
hafren (03-03-2016)
Old 03-27-2016, 04:39 AM
andy pen's Avatar
The insulation mine was completly shot so I have cut it off and I don't think I shall bother to replace it. I cut it along the bottom of the fabric where the heat shield starts.
Old 03-27-2016, 11:07 AM
dsetter's Avatar
When I replaced my hose, I pulled all the padding and replaced with stick on aluminium duct tape. I thought it would reflect some of the heat.
Been 18 months now and no issues.
Old 03-27-2016, 01:15 PM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
Sounds good to me. In a month I will be replacing my valley hose and I already know my firewall padding will mostly disintegrate when I try removing it.
XJeej
03-18-2016 06:06 AM
nasomi
02-16-2016 10:35 PM
Cherry_560sel
02-11-2016 07:27 AM
Pilotman11
02-06-2016 06:19 AM
Quick Reply: Anybody ever replaced the firewall padding?
