audible warn when engaging Drive or reverse
Old Jan 27, 2022 | 05:15 PM
aerophil's Avatar
Default audible warn when engaging Drive or reverse
I have a 2003 X350 and when I engage drive or reverse I get a really annoying audible tone. It is an irregular sound that goes away as oon as I reach approx 10mph. It appears to come from the steering coloumn area. It is not the sound you get with the parking sensors or the one from the seat belt warning.
any ideas many thanks best regards Phil
Old Jan 28, 2022 | 11:18 AM
wfooshee's Avatar
There is a beep that happens when you try to shift out of park without the brake pedal depressed... I wonder if somehow that beeper is not getting the brake signal. Obviously you're able to shift out of Park. Try pushing the lever out of Park without the brake, or even with the car shut off, and see if that's the same sound.
If that's it, as for fixing it I couldn't even begin to tell you where to start...
Old Jan 28, 2022 | 11:51 AM
aerophil's Avatar
Spoiler
Old Jan 28, 2022 | 03:45 PM
meirion1's Avatar
Scan for codes first but possible faulty brake switch
https://www.google.com.au/search?q=j...QA&sclient=img
ben30
XF (X260)
Apr 7, 2018 07:37 PM
dneider
Jan 12, 2018 09:19 AM
Donna
Mar 11, 2014 09:46 AM
Frog
Jun 29, 2011 03:21 PM
Copesetic
Oct 28, 2010 03:02 PM
