Bluetooth that Almost works (but not quite)
Old Nov 27, 2014 | 05:24 PM
Blairware's Avatar
Originally Posted by H20boy
I didn't bring up my PDF of the BT handbook, but isn't there a code to delete all previously paired phones? You are only trying to pair one phone and check its operation before trying another phone, right?
If there isn't a way to clear it, I'd try performing a hard reset by pulling the negative cable on the battery and touching the positive terminal for a few seconds. This will discharge all stored energy in the car's computers and will start from scratch. You'll lose save radio stations, the RBDS will likely be on, and memory on the seats will be lost as well. But, a reset like that has cured many weird symptoms on my cars in the past.
You might want to check and compare the last two letters of the part numbers for your phone module (PSE) in the boot, and your BT module tucked inside the armrest. If the BT module is older than the PSE, that may be your problem.
I am using my Samsung S5, and a PSE/BT combo unit from an X358...so a little newer equipment.
I am getting ready to do some exploratory surgery in the armrest/console - can you tell me where in the console it's located? I imagine I have to pull the whole thing and cannot get at it through the center bin or the shift surround, correct?
Old Nov 27, 2014 | 05:28 PM
H20boy's Avatar
Most install it by going behind the rear a/C vents, and then it lays just behind the little grille on the drivers side of the console. Pop that off first before going in and by pulling the vents.
Forcedair1
Sep 8, 2025 01:57 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Dz1rfj
Sep 16, 2015 03:44 PM
philwarner
Sep 5, 2015 10:05 AM
