Bonnet/hood insulation
Old Oct 11, 2025 | 01:48 PM
Deepstuff's Avatar
Default Bonnet/hood insulation
Hi,
What are people using to hold the bonnet/hood insulation in place? The taps that go inserted into holes in the bonnet are no longer do their job.
Old Oct 11, 2025 | 04:00 PM
Wingrider's Avatar
Replacement if available, or just remove it.
Old Oct 11, 2025 | 07:06 PM
mjcarch's Avatar
I had the exact same issue. I cut some sections about the width of those tabs from a foam pool noodle and used them to hold the tabs in place. Has worked well for me.
Old Oct 12, 2025 | 07:34 AM
Deepstuff's Avatar
Any pictures?
Old Oct 12, 2025 | 12:02 PM
mjcarch's Avatar
The foam I used is that split foam used for insulating pipes. You can get it at most hardware stores like Home Depot or other places. Here are the pictures you asked for.
Foam in tab openings
Push in insulation tab and foam into opening
Section of foam cut to width of opening
Old Oct 13, 2025 | 03:51 AM
LS-GTA's Avatar
That is genius! I used 3M super 77 spray adhesive.
Old Oct 13, 2025 | 12:00 PM
Big Koshka's Avatar
I did this about year ago:
https://www.jaguarforums.com/forum/x...1/#post2777671
Old Oct 13, 2025 | 12:15 PM
mjcarch's Avatar
Big Kosher, yours looks so nice with that new liner....I remember seeing that post.
Old Oct 13, 2025 | 08:29 PM
SeanieFutbol's Avatar
I replaced my hood insulator/liner a few months back with an authentic one ordered by Harper Jaguar Knoxville, fixed all of my problems. I had the same exact spot problem where the tabs were no longer holding it in.
The replacement is worth it, they updated the design so that it better holds itself in place using the clips. Here is the part number: "C2C32839". My replacement ran me about $300 and an afternoon of engine bay detailing.
Oubadah
May 4, 2026 12:44 AM
BenKenobi
Feb 12, 2023 03:59 PM
caferacer
Mar 21, 2017 08:00 PM
8bit
Nov 1, 2013 09:53 AM
bigwiki
Oct 5, 2010 08:26 AM
