Bonnet Open warning light
While driving, they Bonnet Open watching displays with the red light on the gauge watching messages area. Also noticed the car alarm goes off at random moments, while parked. I suspect the two are related. Any ideas where to start troubleshooting?
Check by shorting the cables at the switch. If the warning does not go out, you may have an issue with the earth. The bonnet switch uses the "G1" located behind the headlamp, same side as the air box
34by151
34by151
I was trying to be slick by trying to disconnect the cable without taking off the bonnet latch. However, after removing the latch I was able to get enough purchase to disconnect the cable. After I put a paper clip piece into the connector, taped it up, job done.
rhscare
Sep 13, 2016 10:02 AM
Jaguar Forums Editor
F-Pace (X761) / C-X17
Sep 12, 2016 03:14 PM
