Broken light analog clock
Old Sep 26, 2018 | 02:26 AM
JappieRocks's Avatar
Default Broken light analog clock
HI all,
Should the analog clock on the dash be lighted just like everything else on the dashboard? And if so, is it possible to exchange the lamp?
Old Sep 26, 2018 | 06:18 AM
mhamilton's Avatar
The clock should have a green backlight, yes. The lighting is most likely LED and not replaceable. However if you're handy with a soldering iron it might be worth looking to see if 1) the clock can be opened and 2) if there is a broken solder joint on the board.
Old Sep 27, 2018 | 06:17 AM
rhankey's Avatar
There is a thread on this XJ350 sub-forum from the past that described replacing the clock back-light. If I remember correctly, it does require a soldering iron to replace some sort of LED chip on the clock circuit board.
Old Sep 27, 2018 | 07:22 AM
mhamilton's Avatar
Good call--actually it is just an incandescent bulb! https://www.jaguarforums.com/forum/x...k-bulb-133581/
Old Sep 27, 2018 | 01:25 PM
roviw's Avatar
My clock light packed up a couple of years ago, I did find out from the Forums it was possible to change the bulb but it was a time consuming job. I cheated though, the car was in the garage for something else and I got them to change the bulb.
Old Sep 27, 2018 | 03:46 PM
abonano's Avatar
Nice coverage for changing out the bulb.
Old Sep 27, 2018 | 03:49 PM
Dan R's Avatar
Where else do you get such detailed information with pictures to readily fix such niggling problems? I wonder how much the dealer charges for this?
Trick Freestones
XJ40 ( XJ81 )
Jul 6, 2023 01:45 PM
Hustle Hyde
20
Apr 11, 2022 11:22 AM
Noiseman
Sep 11, 2017 09:46 PM
timwhayden
Dec 8, 2016 09:44 AM
Ashton Dimovski
Aug 14, 2016 03:28 PM
