Can i remove the transmission if the engine is seized?
Old Aug 29, 2023 | 11:36 AM
Vanden Matt's Avatar
Question Can i remove the transmission if the engine is seized?
Long story short my son hydrolocked our 05 VDP last week with the flooding we had in Michigan. I have a good used motor on order and i'm reading the manuals and it asks to remove the trans first. Since i cant turn the engine over how can I get the flywheel off?
Old Aug 29, 2023 | 12:59 PM
Thomas-S.'s Avatar
The flywheel is only accessible once the transmission has been removed from the car, it is not in the way when you remove the transmission.
Best regards,
Thomas
Old Aug 29, 2023 | 04:03 PM
kg74's Avatar
Have you tried turning it by hand? Pull the plugs and spray it with some oil. As the motor is trashed you can turn it backwards and fowards. You can also walk the cams. The valves are what you should be hitting - so with this knowledge you can rotate enough to get the torque converter bolts lined up.
Before going ape, I would pull the spark plugs and spray air into the hole (use a rag to control splash). Then see where you are at.
You have to be careful stressing the transmission - as it sits if you pull the transmission the torque converter will stay with the engine (not optimal) - but most likely will not be harmful if one is careful - the seal will need to be changed out (which one would do regardless). This is why one unbolts the torque converter and it remains with the transmission during removal. Engine side is a nub, transmission side is the oil pump which is splined.
Old Aug 30, 2023 | 09:22 AM
I did take the plugs out when i got it towed home and tried to turn it by hand and it didnt budge at all. My son tried to restart it in the water when it shut off and when I took the air filter was completely soaked when i took that apart. Its been siting now for a few days so i might try again.
Stosh1017
Apr 9, 2023 03:59 PM
Udiasi
Jan 9, 2021 06:46 AM
AussieMark1
24
Oct 23, 2017 05:30 PM
DayOff
XJ40 ( XJ81 )
Sep 19, 2013 05:12 AM
diesellee
Sep 23, 2011 01:50 PM
