Catalytic converteren xj8 4.2 from 2003
Old Jul 6, 2025 | 10:03 AM
Renemarcel's Avatar
Default Catalytic converteren xj8 4.2 from 2003
Can anyone tell me how many pieces are mounted on my car, and if they have to be replaced alltogether when they give a failure in the exhaust
the vin is SAJAA72PO3SGO1264
Old Jul 6, 2025 | 02:28 PM
Thomas-S.'s Avatar
Are you talking about how many pieces the complete exhaust system consists of? Or only about how many catalytic converters the car has?
The car has two catalytic converterters,one for each cylinder bank.
Here you can find all the parts:
https://parts.jaguarlandroverclassic...03-2009-parts/
And yes, if you get original parts, you they will fit together and you will only need to replace a defective part. The same should apply to parts made to OEM standard. The probem is that original parts (or made to OEM standard) are hard to find, and in that case I cannot comment on the fit of other parts.
Best regards,
Thomas
Old Jul 7, 2025 | 04:24 AM
Renemarcel's Avatar
Best regards,
Thomas
thanks for your reply. However, my catalytic repair shop says that there are 4 converters?
Old Jul 7, 2025 | 07:33 AM
redrover41's Avatar
Copied this from Copilot AI:
The 2004 Jaguar XJ8 with the 4.2L V8 engine is equipped with four catalytic converters:
🔧 Catalytic Converter Setup:
  • Two primary (pre-catalytic) converters: Located close to the engine, one on each bank of the V8.
  • Two secondary (main) converters: Positioned further downstream in the exhaust system, also one per bank.
This quad-cat setup is common in luxury V8s of that era to meet stringent emissions standards, especially for California or CARB-compliant models.
🔧 Replacement Options
Direct-Fit Catalytic Converters
These are designed to bolt directly into your Jaguar’s exhaust system with no cutting or welding required.
  • Available in both Federal and CARB-compliant versions
  • Higher cost (~$600–$1500 per unit)
  • Excellent durability and emissions performance
🔧 Universal Catalytic Converters
These are more affordable but require cutting and welding to install.
  • Requires welding
  • Not legal in California or New York
  • Good for budget-conscious DIYers with welding access
🧰 DIY Installation Tips
  • Tools needed: Jack stands, socket set, O2 sensor wrench, penetrating oil, and possibly a reciprocating saw (for old bolts).
  • If welding: Use stainless steel wire and a MIG welder for best results.
  • O2 sensors: Inspect and replace if they’re old or fouled—bad sensors can damage new cats.
Sometime soon, AI is going to tell me where I left my keys.
Old Jul 7, 2025 | 10:21 AM
Thomas-S.'s Avatar
If you look under the car, you will definitely see only TWO catalytic converters, one for each bank.
They look like this, the picture is taken from the Jaguar parts catalogue, and in reality they also look exactly like in the picture. I have had my car on the lift enough times to know, and I have already replaced one of them.
After the catalytic converters, you have the middle silencers and then the end silencers. You can easily check the setup vial the link I have posted in my first answer.
What you mechanics might refer to, and also the text posted by rsa760041 might refer to, is the fact that within each catalytic converter there are two cell packs, with an oxygen sensor placed in between them.
Each cell pack could also form a separate catalytic converter if packed into a separate enclosure, but this is not the case with our cars.
So, technically speaking, it could be considered that the car has 4 catalytic converters, but if you talk about the catalytic converter as the part that can be bought as a spare from Jaguar, then you only have ONE for each bank, as shown in the picture.
Everything else would mean buying the internal cell packs, opening the enclosure of the catalytic converter, replace the cell packs, and re-weld the enclosure to close it. Maybe your repair shop is talking about this procedure, instead of a spare part as sold by Jaguar.
The point is that normally, when you speak about catalytic converters, you talk about the part to be replaced "as is", and not about replacing the internal cell packs.
Best regards,
Thomas
Old Jul 7, 2025 | 01:06 PM
Petz's Avatar
2 catalysers on xj6 and xj8 and xjr and super v8
i have 3 2003 cars g08679 g23600 g 5 and someting another g5 and something build the same day . And even the x356 daimler H18000 with supercharged 4.2 only has two I ve been changing one of them.
your car is a very early one 2002 or 2003
Old Jul 8, 2025 | 04:19 AM
RobRAK's Avatar
On your catalytic converter should be a part number plate, in my case 2W93 5E212 ED. The middle part 5E212 references to the catalytic converter body, many Ford cars have the same catalytic converter installed with a different part number in the beginning, which refers to the pipe fitting. I got my catalytic converter repaired for about 200 USD by an exhaust shop. They took a good used Cat from a Ford breaker car which had the part number 5E212 in the middle and transplanted the cells into my cat. Works perfectly.
there was another thread recently for catalytic converter replacement for a supercharged, there was a link to a seller on ebay who is selling a pair of cats direct fit for as little as 150 USD. Not sure about emission testing and durability, that's why I went with a used OEM cell.
mine got damaged when accidentally hitting it during transmission install.
Old Jul 8, 2025 | 05:36 AM
Renemarcel's Avatar
thank you for your help
Old Jul 8, 2025 | 05:37 AM
Renemarcel's Avatar
Old Jul 21, 2025 | 02:43 AM
Renemarcel's Avatar
Default Confusing
[QUOTE=Thomas-S.;2855670]If you look under the car, you will definitely see only TWO catalytic converters, one for each bank.
Best regards,
Old Jul 21, 2025 | 02:44 AM
Renemarcel's Avatar
Default Confusing
They look like this, the picture is taken from the Jaguar parts catalogue, and in reality they also lopok exactly like in the picture. I have had my car on the lift enough times to know, and I have already replaced one of them.
Best regards,
Old Jul 21, 2025 | 02:45 AM
Renemarcel's Avatar
Default How can i reply on these posts?
Best regards,
Old Jul 21, 2025 | 06:34 AM
Thomas-S.'s Avatar
You press "quote", and the post you wanted to quote appears again.
Just scroll down within the quoten post until you reach the end of it, shown by the "/quote", place the cursor after it, press enter once or twice to go to a new line, and type you message afterwards.
Best regards,
Thomas
XJ8 4.2
Aug 20, 2024 02:54 PM
TLW
Jan 9, 2023 07:22 PM
Isoruku
Oct 15, 2022 04:31 PM
Jeff Wren
Jan 24, 2020 12:41 PM
nsx4pete
Mar 27, 2008 07:08 PM
