Changing out overhead panel
Old Apr 30, 2014 | 12:11 AM
Rufus T. Firefly's Avatar
Default Changing out overhead panel
I'm looking to change out the eyeglass cubby and the bezel around the switch panel from my fabric version to the Burl wood type. Anyone know of a source that won't break the bank? Or... is anyone interested in a swap?
Rufus
Old May 2, 2014 | 10:14 PM
BrentGardner's Avatar
Hi, I did not know there was a burl wood option for that eyeglass holder part on the X350 cars. Please post a pic if you find a burl wood one.
Old May 2, 2014 | 10:59 PM
Default Like this...
I think it is installed on VDP models... but should also fit non-VDP
Attached Thumbnails Changing out overhead panel-01616_3dveghbqjuf_600x450.jpg
Old May 3, 2014 | 12:21 AM
Cambo's Avatar
The roof console is the same on the later S-Types as well.
The veneer is held on with double-sided tape, I pulled one apart recently. The easiest way to get it apart was put the whole console in an oven (i set the oven to 60°C) which will soften the adhesive without melting the plastic. Then with a thin plastic scraper, just work the adhesive loose.
As for where to get one, the veneer was not available to buy separately AFAIK, so your best bet will be to have a look on ebay.
A new console is $$$$ so 2nd hand will be the most economical way to go.
EDIT
A picture of the actual console here https://www.jaguarforums.com/forum/a...20/#post934890 but it's been sold.
EDIT again, couple on ebay right now
http://www.ebay.com/itm/Jaguar-2004-...d8f518&vxp=mtr
and
http://www.ebay.com/itm/Roof-console...item2ed0b8a114
Old May 3, 2014 | 11:15 AM
Thank you Cambo351
Old May 3, 2014 | 05:18 PM
oilstain's Avatar
Still won't fit actual sunglasses though...
Old May 3, 2014 | 06:16 PM
So true...
FrickenJag
Jun 16, 2025 02:15 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
sadepol01
Sep 11, 2015 05:26 AM
