Clarification: Adjusting High Beam Headlights
Old Aug 23, 2018 | 11:05 AM
Blairware's Avatar
Default Clarification: Adjusting High Beam Headlights
I have read a fair amount of, if not conflicting, you could say differing info on our Headlights and methods to adjust them. Here is my issue, and I am hoping to get some clarity on this.
There are some eary cars that use the air suspension to level the car, and thus the headlights. They do so in a smart way, always leveling the rear of the car first, and then the front in an attempt to mitigate blinding oncoming drivers. My car, a 2007 Vanden Plas doesn't have any of this, nor does it appear to have any automated or motorized headlamp aiming mechanism. What it does have is a 6mm hex fitting that allows vertical adjustment of the low beam HID (previously called "Xenon") headlights. They work well, are bright, white and focused decently through a projector lens.
The high beam adjust is in the middle of the housing - The presumably High Beam adjust is over the inner housing - except it doesn't appear to do anything - I have spent a lot of time running the adjuster from one extreme to another - with virtually no notable effect. I will post a few pics of these when I get home from work today. Except my high beams leak light pointing almost straight up.
Any thoughts, experiences, instructions etc. would be SO appreciated!!!
Old Aug 23, 2018 | 05:16 PM
meirion1's Avatar
The 6mm hex white adjuster is all I have.
I have adusted mine and you should see the effect very quickly.
It sounds to me that yours has 'let go'
I can only imagine that you are faced with removing the unit
and dismantling it to attempt a repair.
Used ones are not cheap.
Old Aug 26, 2018 | 07:18 AM
Blairware's Avatar
Default Here's the pics
Note that BOTH of the inner adjustments toward center of car do nothing. There is no problem with my headlight aim at present. I just need to find out what the inner adjusters do, as my high beams seem to leak a bit of light upward. Anyone?
mikelanzetta
Sep 30, 2016 02:32 PM
cybercg
Sep 30, 2013 03:43 PM
82jaguarxj6
Jul 28, 2013 03:04 PM
satwarez
Jan 13, 2011 08:31 AM
Jan 2, 2007 04:37 PM
