Clonking noise on front driver wheel - still chasing the problem
Old Mar 20, 2013 | 02:43 PM
  #41
magik's Avatar
ok my noise was from leaking trans cooler lines,replaced for $600.no more noise.
Old Mar 23, 2013 | 05:26 PM
  #42
magik's Avatar
ok,noise back...man,i don't know that was good idea to buy jag.,and some small problem with transmission,from first to second gear i feel some little jump.
Old Mar 24, 2013 | 11:31 PM
  #43
H20boy's Avatar
didn't think a cooler line would be the cause of the noise, unless it's securing mount was really loose.
Did you have the dealer, or at least a ZF experienced tranny shop refill your transmission? I bet you're levels are off if you didn't. Its a precise method to get just the right amount.
Old Mar 25, 2013 | 12:28 AM
  #44
SaturnV's Avatar
Omitting the dipstick has just got to be a conspiracy to force ZF equipped cars back to the dealer.
Old Mar 26, 2013 | 05:07 PM
  #45
magik's Avatar
H20boy thanks for replay,i just back from jaguar dealer,noise fixed-was break pads clips missing,replace front break pads with clips and noise gone.About the transmission jaguar mechanic say is fine,but the find thermostat tower + hose coolant leaking=$790 to fix.
I will wait.
Old Apr 19, 2013 | 01:41 PM
  #46
jbarringer's Avatar
Originally Posted by Peter Connell
Long shot, but in the essential buyers guide by Nigel thorley he mentions a hidden section of aluminium riveted to the main structure and the bumper bolted on the other end. This area is intended to collapse in an accident.he says a clicking sound of clunk from the front of the car is caused by the rivets loosening on the super-structure. These rivets can be drilled out and replaced by bolts which is a recommended jaguar fix. Probably not this but worth a look?
This happened to me. I bumped into a wall opposite my house when it was icy. The car was repaired at a body shop and everything seemed fine. The clonking didn't start until about a year later and progressively got worse and worse. I finally took it to a local independent Jaguar garage who found that the rivet holes had elongated over time, probably caused by the initial bump. They did exactly what you described: drilled them out and fitted bolts. Clonking now gone!
Old Apr 20, 2013 | 05:48 AM
  #47
talashek's Avatar
Thanks jbarringer, i will give it a shot and report back. TT
Malihide
Apr 11, 2026 02:58 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
tberg
Aug 31, 2015 04:33 PM
timm525
Aug 29, 2015 04:49 PM
