Code P0171
Old Sep 27, 2021 | 06:07 AM
Oats's Avatar
Default Code P0171
Gooday, I'm oats from Botswana owning an x350 jaguar v6 and my problem here is performance..I diagonised the cat and I'm getting code P0171 and I'm not sure if it's the fuel filter,flow plugs or something else...it does take off sometimes it does and when it reaches a certain stage it doesn't and the refs will be fluctuating..what might be the cause
Code received
Side view
Xj6 x350
vin
Old Sep 27, 2021 | 06:17 AM
quattrofrank's Avatar
Its not very easy to read the fault codes on your first picture.
Would be nice if you could type them in here. I see a fault code regarding cam postion sensor and this could typically cause the engine to go into limp mode. Then it will be low an performance and the idle will fluctuate
p.s I like your rims, what kind of brand and model is that?
Old Sep 27, 2021 | 12:27 PM
Oats's Avatar
sorry about that I uploaded a wrong picture...but the code is about oxygen sensor being intermittent and the car dies have take off as it used to be
Old Sep 27, 2021 | 12:31 PM
Oats's Avatar
I removed the glow plugs just now but I found out that 2 of the plugs were affected by water since I once cleaned the engine..now when I press the accelerater the engine light blinks but when I press gently it doesn't...
Old Sep 27, 2021 | 12:34 PM
xalty's Avatar
you may want to ask on the uk jaguar forum
most people here have no experience with the diesel
Old Sep 27, 2021 | 12:52 PM
Oats's Avatar
it's petrol not diesel
Old Sep 27, 2021 | 01:39 PM
MoJo88's Avatar
Last week I cured a Vauxhall Corsa D that had this fault along with a really rough idle. It was the Purge Control Valve and it only cost £20.
Old Sep 29, 2021 | 10:51 AM
JagV8's Avatar
Petrol doesn't have glow plugs, does it?
Did you mean spark plugs?
Blinking (flashing) MIL = severe misfires, doing actual catalyst damage - DO NOT KEEP DOING THAT
There are many threads about P0171 - follow them
Old Sep 29, 2021 | 01:05 PM
Oats's Avatar
The code given is system too lean,I meant to say spark plugs
Old Sep 29, 2021 | 04:09 PM
JagV8's Avatar
Do what others have done - Search is worth using.
Terry007
Mar 9, 2021 10:32 PM
jalsina
Dec 19, 2020 05:45 PM
TonyJ1977
Feb 12, 2020 12:47 PM
Ramez Melli
Nov 15, 2019 01:30 AM
test point
Sep 29, 2010 10:21 PM
