Code P0420 Cat Converter Efficiency?
Old Apr 3, 2016 | 06:05 PM
hisport's Avatar
Red face Code P0420 Cat Converter Efficiency?
My '07 XJR (90k miles) is showing a CEL, and DTC is P0420 "Bank 1 Cat Converter Below Efficiency Threshold"
I erased the code, but it comes back and flips on the CEL
Anyone else encountered this?
I searched the forum, and there are a couple threads about seafoam cleaning, etc, but only final resolution I read was to replace cat
Had a bad cat on my an 8 yr old Mercedes, and the dealer replaced it under (an EPA mandated?) 10 yr/100K mile emissions warranty. Does this maybe apply to our aging Jags?
Old Apr 3, 2016 | 09:09 PM
Box's Avatar
Box
Switch downstream O2 sensor from left to right respectively. If it follows the O2 sensor, you found the problem. If it returns after you swap left and right. you may look to cat itself. Dealer should honor if bad cat.
Old Apr 4, 2016 | 12:39 AM
plums's Avatar
I suspect that the sensor is also part of the emissions system,
and hence covered under the emissions warranty. If that is the
case, I wouldn't be bothered with the knuckle bruising job of
swapping sensors around. I'd take it in and have them do
whatever was required.
Old Apr 4, 2016 | 07:54 AM
hisport's Avatar
Thanks Box and Plums!
Are the (downstream) O2 sensors a bear? I like the swap idea, as believe the jag dealer will otherwise fight to make this a "customer pay" job
Which is "Bank 1" (R or L)?
Are cats common failure item with these cars? (I'm new to X350 Jags)
Old Apr 4, 2016 | 08:23 AM
Box's Avatar
Box
Bank 1 is right side. Get an O2 sensor socket at local parts store. Takes only a couple of minutes to swap. If it follows O2, and sets P0430 after change, then replace sensors. If it still sets P0420, you can have a melted cat, oil or fuel contamination. Misfire or overheating can melt the cat. Never drive with misfire, as you are dumping raw unburned fuel into the cat, where it then ignites and melts it down. Use Denso brand O2's only, and they are less than $50 each for downstream, about $100 each for upstream online.
Dealer may or may not assist, as it will depend on the Service Manager.
Old Apr 4, 2016 | 09:17 PM
1 of 19's Avatar
Is it 10 yr/100k or 8yr/80k for a 2007 MY Jag.
Old Apr 5, 2016 | 07:03 PM
hisport's Avatar
Thanks Box
It was the RH cat in the only other forum thread I could find on P0420; perhaps susceptible?
I have an O2 socket, and will swap as you suggest
Have no misfire codes, etc, but this is a used car with unknown history. Seems to run well, and no oil consumption in the ~ 1500 miles home
Intake tube "dongle" was broken and leaking air downstream from the MAF, so fuel trim has been way off for some time. Maybe this was it, and caused a lean misfire
1 of 19: Do you see 8/80 emissions warranty for the '07? I have not researched...
Old Apr 6, 2016 | 02:20 AM
doc's Avatar
doc
yep sounds like rich mixture killed the cat (LOL)
Old Apr 6, 2016 | 10:08 AM
Box's Avatar
Box
Thanks Box
https://www3.epa.gov/obd/pubs/420f15035.pdf
Old Apr 6, 2016 | 10:23 AM
hisport's Avatar
Thanks Box!
You're the man...
(I'm 1 year and 10k miles late, sigh)
ericjansen
Mar 21, 2016 02:04 AM
3434char
Mar 20, 2016 08:48 AM
Shelorr
Mar 9, 2016 08:46 PM
klfong
Mar 6, 2016 12:08 AM
