Config E Mode after IDS messing around
Old May 22, 2022 | 08:24 PM
Dante Guthrie's Avatar
Default Config E Mode after IDS messing around
Hello, I recently got a Mongoose cable clone and was messing around with IDS to reprogram the ABS module in my 04 XJR. It gave me a message saying something fatal then CONFIG E appeared on my dash board. Tried driving after and all seemed fine the but the message persists. Really freaking out as to what I should do now!
Old May 22, 2022 | 09:29 PM
abonano's Avatar
Did you have a power supply on the battery when reprogramming the module? Also, you might be screwed programming a module with a clone!
Old May 22, 2022 | 09:57 PM
No power supply, but it had a new battery and I only hooked it up for 15 mins
Old May 23, 2022 | 11:00 AM
OldKarz's Avatar
Not good enough! Programming requires over 13 volts and your battery alone will not supply that.
Old May 23, 2022 | 11:32 AM
abonano's Avatar
No good.
You need at least a 30 amp regulated power supply on the battery when programming any module and I'll defer to my previous point, your rolling the dice configuring any module with a clone cable.
Old May 25, 2022 | 03:12 PM
Wingrider's Avatar
You could use another running vehicle, with jumper cables to supply voltage.
Old May 25, 2022 | 09:35 PM
abonano's Avatar
Eh, may or may not work....
Old May 26, 2022 | 07:59 AM
Wingrider's Avatar
Saw someone on the computer using another vehicle to supply voltage.
Thought with no other option for steady voltage, this should work.
But i could be wrong.
Old May 28, 2022 | 01:29 PM
Thanks for the replies. In retrospect of my stupidity I am not sure how to proceed. I will not be messing around with that clone cable anymore. Shouldn't a Jag dealer be able to reset the ECU no problem to resolve this?
Old May 28, 2022 | 02:48 PM
OldKarz's Avatar
When they were current on the model they could have done it with their eyes closed. However even the techs that were there have only a vague memory of what to do. When a module fails to communicate there is a very specific time dependent procedure for bringing it back to life. A main dealer probably would not want to touch it. However many independents are still current enough to work through the procedure.
I have done it, just a DIYer, with the 131 SDD and the latest JLR VCI. Took a while before I got it right, but wasn't paying by the hour! 131 is actual Jag software, not a crack, that works since, if the date is set right, it thinks it is current.
Old May 30, 2022 | 08:38 PM
Sadly no independent shops in my city have OEM dealer software. Do you have a recommendation for where to buy the JLR VCI? Also what computer were you running SDD on? Does the JLR come with software? I was virtual box on windows 11 when I messed mine up.
Old Sep 26, 2022 | 10:41 AM
OldKarz's Avatar
FIXED. An update on this thread. Dante brought the car to my place and we worked on it there. There were a number of issues - mainly ground problems - we dealt with before starting the main fix. The last try was programming the ECM to get rid of the config-e message. It failed and the ECM was put off line. We tried the recovery procedure and it also failed. The car was dead in the garage, it was late so Dante borrowed one of our cars and went home. Next day I went over the grounds again and cleaned up the ones at the headlights. Tried a re-program with same results.
Ran tests on CAN lines. There was a ground fault on the bus. Jumped to the ABS module since I have seen the same on two others. It had the short internally in the module. They still work with the partial short but make programming the ECM fail.
Disconnected the ABS module and jumpered the connector CAN lines. Did a reprogram on the ECM and it worked when the recovery procedure was done. Config-e was eliminated and the car was functional again.
Sangeeth Mullassery
31
Jan 10, 2025 03:54 AM
XxSlowpokexX
US Northeast
Jun 1, 2022 08:46 PM
^SiRtA^
42
Aug 29, 2021 10:38 PM
nalle
Nov 29, 2019 11:47 AM
Revonok
Nov 24, 2014 07:50 PM
