control Modules
Old Oct 29, 2019 | 08:28 AM
Jaguarman22's Avatar
Default control Modules
Hi every body
I think your going to love this one
2003 x.350 v.6 3.0
so this car has a miss fire around 2000 rpm been right throw it over last 18 months every thing on the engine changed so derided to change the ecu as i know it did get wet
so there is a ecu in the engine bay
ecu in front passengers side foot well
ecu in drivers side boot
speedo cluster where else as it keeps telling me that the wright control panel has bad info ! and locks steering
I know it isn't any of the above as they have all come from the same doner car so there must be another one some where the only code she is giving me is B2162 any ideas where it is hiding Michael
Old Oct 29, 2019 | 02:55 PM
wwr's Avatar
wwr
Jaguarman22;
The DTC Summaries suggests this code could be generated from any one of three CM's:
You can get the DTC Summary file here.
The Jaguar X350 Electrical Guide 2004 has CM description and locations.
Best Regards, William
Old Oct 29, 2019 | 03:36 PM
wwr's Avatar
wwr
Michael; Did you swap your CM's and have them reconfigured -or- did you just swap the CM's? Look in the possible causes section of the table above.
WW
Old Oct 29, 2019 | 04:36 PM
Hi i have swapped Engine
+passengers +Boot + Instrument panel I have been told the steering lock module has to be swapped as well this is the only fault i am getting so will do that tomorrow all good fun
Mikedarija1
Apr 27, 2019 10:18 AM
Bruiser
Jan 9, 2019 09:55 PM
Robert Gladding
Aug 1, 2017 08:45 PM
Mountaineer
May 6, 2017 02:17 PM
joesoap
Sep 10, 2015 01:09 PM
